REW and home stereo setup - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration
Discuss REW and home stereo setup in the Subwoofer Equalization | Calibration forum; REW and home stereo setup Hi guys, I need some help,how to use REW with home stereo.I know,that REW was made for home cinema.But I ...
Old 04-02-08, 04:57 PM   #1 (Link)
New Member
Alias: eLko
User: #18186
Since: Mar 2008
eLko is offline
Hi guys,
I need some help,how to use REW with home stereo.I know,that REW was made for home cinema.But I think,that I can use it for stereo as well.
I have laptop,maudio mobilepre,ecm8000.I was reading this forum and find out,that I need to calibrate mic,soundcard and SPL meter in REW.Correct?
For mic,I use the cal file.For soundcard I have to do loop from input to ouput and calibrate response of the soundcard.Correct?
And for the SPL meter,I will need external analog or digital SPL meter and value set to the REW.Right?
Do I need to calibrate something else?
Than my external DAC has usb input.So I use my DAC as an output device and maudio as an input device.So I can make sweeps from REW and sound should come out from my speakers and mic should make measurement and I should find out where do I have peaks.Right?
Please,can somebody confirm,that it should work like this or do I have to do something else?
Thanks
Old 04-02-08, 05:24 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: REW and home stereo setup
Not at all, it doesn't work for multi-channel actually. The receiver or processor must be used in stereo mode.
Yep............
For soundcard I have to do loop from input to ouput and calibrate response of the soundcard.Correct?.
Or simply hook a loopback to the left channel (line-out to line-in) of the soundcard. This acts as the calibration when the checkbox is ticked.
Old 04-02-08, 05:40 PM   #3 (Link)
New Member
Alias: eLko
User: #18186
Since: Mar 2008
eLko is offline
Thanks for the reply.
So.When I calibrate soundcard once,than I dont need to have that loopback when I do measurement?Because I am not going to use maudio as an output device for measurement.It will be my dac.Maudio as an output device will be used only for soundcard calibration.Right?
In settings,there is that checkbox for left channel reference calibration.I should check this only if i am using maudio as an output device for measurement and loopback is on.Right?
Thanks
Old 04-02-08, 05:54 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Yes, if the box is unticked you'll be using the soundcard cal file that you produced and stored (instead of using the left channel loopback).
But, here's the rub with your logic. You are including a piece of your UUT (unit under test) into your test equipment.
The standard method is that you calibrate your test equipment (usually a PC soundcard with analog line-out and analog line-in) with an external loopback cable, so that when the loopback is measured it returns a perfectly flat response.
Then when you hook this perfect test eqiupment up to the UUT (in most cases a preamp/amp or receiver with sub and or mains speakers and a room using a flat microphone) the response will be the UUT only.
Do you see what you're doing? You want to include the DAC in both the test equipment and the UUT. To do so, you'll have to accept the assumption that the DAC is perfect and so its influence will be a wash.
Old 04-03-08, 07:50 AM   #5 (Link)
Alias: Greg
Loc: NY
User: #13758
Since: Nov 2007
glaufman is offline
brucek wrote: View Post
I think more to the point, he won't be assuming the DAC is perfect, but that it perfectly matches the DAC internal to the m-audio... The internal DAC's response has already been included in the cal file he's producing, but then he's removing it from the test setup...
Old 04-03-08, 07:59 AM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
Yep................
Old 04-03-08, 05:40 PM   #7 (Link)
New Member
Alias: eLko
User: #18186
Since: Mar 2008
eLko is offline
So I calibrated my soundcard using loopback and created cal file.Response is perfectly flat.
Now what I want to say is,that I have stereo system made of cd transport,external dac,preamp,active monitors and active sub.
When the soundcard is calibrated,I can do some sweeps now.Questions is,how.
As I said before,my dac has usb input and I can select my dac as an output device in REW and testing sweeps will not go trough maudio,but directly from pc to dac.I can select only one output device in pc,so maudio output is disabled and dac is enabled.
Test tones go to dac and maudio will receive response from my speakers through the mic.Thats the first option.
Second.Output device will be maudio and I have to go from maudio to the preamp.But cd transport and dac wont be in my stereo chain.
Third.I can do cd with test tones and play those tones through cd transport.Than O dont know what should I setup for output device.Should I select maudio and use loopback?And I have to start meauserement simultaneously with meaeserement in REW.
Thanks
Old 04-03-08, 08:02 PM   #8 (Link)
Alias: mfine
User: #10669
Since: Aug 2007
m-fine is offline
Follow the second one. Any error from the CD transport and DAC are NOT what you want to correct with EQ anyway. You are looking for room resonances and using EQ to pull them out. Besides, any error from the DAC ought to be smaller than your measurement accuracy if it is a half decent DAC.
Old 04-03-08, 09:08 PM   #9 (Link)
Alias: brucek
User: #6
brucek is offline
Yeah, go with this method.......
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration »
Similar Threads
Help With Home Theater Setup! tonybologna Remotes | Cables | Accessories 29 01-18-08 02:20 PM
Car Stereo to Home Theater (Ported Box Plans Needed) I have pics Shinisa SoundSplinter 10 07-29-07 03:57 PM
Sub EQ for Stereo vs. Surrond setup dmccombs BFD Forum 9 03-30-07 03:27 PM
Please help with hardware setup for REW gkaste REW Forum 7 02-22-07 10:28 PM
complete noob: can REW be used to measure stereo response? tboooe REW Forum 8 06-26-06 02:21 AM
Mach 5 Audio
