| SPL Meters | Mic's | Calibration Galaxy 130 and/or PCM-6100 micDiscuss Galaxy 130 and/or PCM-6100 mic in the Subwoofer Equalization | Calibration forum; Galaxy 130 and/or PCM-6100 mic I'm looking to purchase the equipment I'll need to test my theater since my room is inside a concrete bunker ... |
| | #1 (Link) | |||
| Galaxy 130 and/or PCM-6100 mic I'm looking to purchase the equipment I'll need to test my theater since my room is inside a concrete bunker (half joking, all 6 surfaces are 8"-2' concrete). The room can't be framed for a few reasons so I'll be working on getting the right kind and amount of AT. Anyway, I was wondering if anyone had a comment on the Galexy 130 rather than 140 SPL? It's half the cost so I thought it would be worth asking about. The second thing is I have a yamaha 12/4 mixer I use for recording and a few mics, one of which is the e-bay famous PCM-6100 that has a fairly flat response: http://www.extras4u.com/faq/product/...rophone_01.jpg It also sounds like you can do testing either just with the SPL or just with a mixer and condenser mic? I guess the pro to doing both is you can verify by doing it with both? | |||
| | #2 (Link) | |||||
| Re: Galexy 130 and/or PCM-6100 mic Quote:
brucek | |||||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| MCH PCM and PCM192K ??? | bobh33 | System Setup and Connection | 2 | 03-13-08 08:20 AM |
| PCM 5.1 or Not. | devicente | High Definition | HD-DVD | Blu-ray | 3 | 11-14-07 08:21 PM |
| Do I need a Galaxy CM-140 | gerhardwessels | SPL Meters | Mic's | Calibration | 24 | 11-08-07 03:09 PM |
| Galaxy CM-140 | drew01484 | SPL Meters | Mic's | Calibration | 7 | 05-25-07 08:33 AM |
| First Galaxy 140 results. | Chrisbee | REW Forum | 28 | 04-05-07 01:37 PM |
