Is this preamp OK? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration
Is this preamp OK?
Discuss Is this preamp OK? in the Subwoofer Equalization | Calibration forum; Is this preamp OK? Hi Is the Behringer TUBE ULTRAGAIN MIC100 Preamp preamp OK with the ECM8000? I can get one at a very ...
Old 01-05-08, 06:35 AM   #1 (Link)
Alias: JulianC4
Loc: Sydney Australia
User: #1461
JulianC4 is offline
Is this preamp OK?
Hi
I can get one at a very reasonable price.
Regards JC4
Old 01-05-08, 07:21 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Is this preamp OK?
Well, if you look at the specs it reads:
It features a carefully selected 12AX7 vacuum tube with UTC technology for exceptional warmth and lowest noise. Thus, the MIC100 can be used to eliminate the "dull" sound of standard digital recorders and sound cards. Also, it perfectly complements studio-grade condenser microphones. Dedicated Low Cut filter eliminates unwanted noise, e.g. floor rumble. .
All this verbiage really means is that it has anything but a flat response that you would require for a piece of test equipment to measure a room using REW. The HPF look undefeatable, so your bottom end would be cut off; which may render it uncompensatable if attempting to include the preamp in the soundcard cal file.
You'd be better off with a solid state preamp that enjoys a flat response...
Old 02-07-08, 04:28 PM   #3 (Link)
Alias: jer
Loc: ct
jeremy7's Avatar
User: #16574
Since: Feb 2008
jeremy7 is offline
I just bought that same preamp for use with my ecm8000. i guess ill try to return it. any suggestions on a solid state pre amp with flat response?
thanks
Old 02-07-08, 05:20 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Yes, the preamp we recommend is the XENYX 802
Old 02-07-08, 05:42 PM   #5 (Link)
Alias: jer
Loc: ct
jeremy7's Avatar
User: #16574
Since: Feb 2008
jeremy7 is offline
thanks brucek
Old 05-03-08, 03:45 AM   #6 (Link)
New Member
Alias: JeanMarc
Loc: france
User: #20317
Since: May 2008
JMRaudio is offline
We need just one microphone input, why not consider the XENYX 502 only ?
Old 05-03-08, 06:56 AM   #7 (Link)
Alias: brucek
User: #6
brucek is offline
No phantom voltage feature.................
Old 05-04-08, 05:27 PM   #8 (Link)
New Member
Alias: JeanMarc
Loc: france
User: #20317
Since: May 2008
JMRaudio is offline
Thanks a lot !... I didn't see there is no phantom voltage,
... and no input gain trim !
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration »
Similar Threads
Looking For 5.1 Preamp buggers Classifieds - Audio Equipment 4 05-09-08 02:36 PM
Microphone preamp in BFD? warnerwh BFD Forum 1 11-06-07 04:48 PM
Advice Needed For A Used 5.1 Preamp buggers Home Theater Components 9 10-15-07 03:32 PM
Question about mic preamp kengrayfield SPL Meters | Mic's | Calibration 4 09-27-07 07:07 PM
HK635 Preamp? Nick77 Home Theater Components 3 03-19-07 06:21 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193
