| SPL Meters | Mic's | Calibration vistaDiscuss vista in the Subwoofer Equalization | Calibration forum; vista So I got a lap top Compac Presario F700 with Vista and the Creative Soundblaser LIve 24bit external. I loaded ... |
| | #1 (Link) | |||
| vista So I got a lap top Compac Presario F700 with Vista and the Creative Soundblaser LIve 24bit external. I loaded the Vista driver that came with sound card. Nothing looks the same as the posts show. I can't even get REW to recognize the sound card in the settings window under Output Device and Output. Tom | |||
| | #2 (Link) | ||||
| Re: vista Quote:
You can look at the thread where I do indicate a card I have been successful with, but I'm afraid I have no experience with the Live card. brucek | ||||
| | #3 (Link) | |||
| Re: vista Sounds like the Audio Advantage SRM is the way to go. I'll be ordering it tonight. I really don't feel like jacking around with SB live, at least it was relatively inexpensive. Thanks for the help. Tom | |||
| | #4 (Link) | |||
| Re: vista So, I just got my Galaxy 140 and the SB Live External SC... I'm running Vista on my I-Mac (boot-camp). This thread is the first I've heard that I may have problems with Vista and the SB Live! card. Is there a fix or work-around? I'm very excited to get my Dali/Ultra system calibrated and my room acoustically treated... Thanks! Dali Mentor 8/Vokal/Ikon Phantom 5.1; SVS pb13 Ultra; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Heaven! ![]() Now about that projector... | |||
| | #5 (Link) | |||
| Re: vista I installed the Audio Advantage SRM sound card. I did the set up to do the calibrations. When I try to calibrate the sound card every thing goes fine but I don't have the graph showing the frequency response of the sound card. What am I missing? | |||
| | #6 (Link) | ||||
| Re: vista Quote:
When you say fine, do you mean the input and output VU readings were good? brucek | ||||
| | #8 (Link) | ||||
| Re: vista Quote:
You need to show some pictures or something..... brucek | ||||
| | #10 (Link) | |||
| Re: vista Let's forget about REW for a bit and see if the card is installed correctly. When you examine the Playback and the Recording Devices (by right clicking the speaker in the System Tray of Windows), do you see the SRM soundcard shown as seen in the pics below? You should see both the laptops on-board soundcard and the SRM soundcard listed in both. Playback devices shows SRM analog and digital outputs plus the onboard device ![]() Recording devices shows the SRM two analog and one digital inputs plus onboard device ![]() brucek | |||
| | #18 (Link) | |||
| Re: vista I'm a bit confused. I thought you said, "I don't have the graph showing the frequency response of the sound card. What am I missing?". That's the soundcard graph. It just has a bit of oscillation at the upper end. You can clear that usually by playing a bit with the sweep and input level to clear it up. Try a few different levels and get a clear graph and save it. brucek | |||
| | #19 (Link) | |||
| Re: vista I uninstalled REW and reinstalled it. Must have missed something the first time around. I'll play around with the sweep and input level and see what happens. Thanks for the help so far. | |||
| | #21 (Link) | |||
| Re: vista REW can't control input level with Vista, levels have to be controlled via the properties for the input device selected on the Recording tab of Vista's sound properties, there is a tab in the device properties to set levels. | |||
| | #22 (Link) | ||||
| Re: vista Quote:
You'll see the Line-In listed as a SRM device in that tab. You then ensure that the Line-in is selected as Set Default (as shown at the bottom left of the overlayed pic below). Select properties of the Line-in and then select the Levels tab and you'll see the Volume contol for Line-in as shown in the bottom right of the pic below. Also be sure the little speaker icon beside that volume control isn't red and disabled. If so, click it to enable. Actually in my VISTA system with the SRM soundcard I can select input volume from REW since it recognizes the Line-in of the card. This work nicely on my system, but isn't needed really, since you can control it directly from Vista as we already covered. I'm not able to select output volume with REW, so I need to select the Playback Devices (as you will too) for output level. brucek | ||||
| | #23 (Link) | |||
| Re: vista I had to take a break for a while and now I'm backat it. No matter what settings I use with the sweep and input level the oscilation won't clear up. This the best I could get. ![]() | |||
| | #24 (Link) | |||
| Re: vista It would be fine for measuring your sub, but you wouldn't use it for measurements above 2KHz. Usually a combination of the levels will always clear that up though. I can't think of anything else to suggest.. brucek | |||
