Question about digital RS SPL meters - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Discuss Question about digital RS SPL meters in the Subwoofer Equalization | Calibration forum; Question about digital RS SPL meters I have access to/use of a RS digital RS meter. It looks exactly like the one pictured in the download ...
Old 08-04-06, 09:37 AM   #1 (Link)
Alias: GB
Loc: BC Canada
User: #1842
Greybeard191 is offline
I have access to/use of a RS digital RS meter. It looks exactly like the one pictured in the download thread for correction factors.
Problem: This meter is referred to as "new", and poking around various forums, it seems that the mic is better/more linear than the old analog version. However, I get the impression that this change (new mic, which also made it into the analog meter) is comparatively recent (last couple of years anyway).
So... the meter I am using is at LEAST 5 years old, probably older (maybe even 6-7 years old). It looks exactly like the one pictured though.
Which correction factors do I use? Are there different version of the digital meter, or versions with different mics?
thanks.
GB
Old 08-04-06, 10:19 AM   #2 (Link)
Loc: Lower Alabama
Re: Question about digital RS SPL meters
Hi GB and welcome to the Shack!
It's possible that there was a change in capsules used sometime over the last few years, but unfortunately we have no way of knowing when and the exact details. I have emailed several corporate people at Radio Shack but can't get a straight answer. I think those meters are or were put together overseas and possibly RS didn't control what parts went in them. The builder probably shopped for the best bulk pricing.
At some point in time, I think (not positive) that RS has started using another source to build these and they are now more consistent than they use to be.
I believe it would just be a shot in the dark with an older meter as to which corrections would work properly.
Old 08-04-06, 04:17 PM   #3 (Link)
Alias: GB
Loc: BC Canada
User: #1842
Thanks for the welcome...
I plugged all the numbers into both spreadsheets (new digital/old analog), and the differences are essentially a steeper "house curve"... It sounds reasonable to my ears, so I'll stick to EQing the peaks and valleys to match the general slope of the curve.
thanks again
GB
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
