sine waves - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
sine waves
Discuss sine waves in the Subwoofer Equalization | Calibration forum; sine waves I downloaded the sine waves to a cd and on the 16hz and up to a few others there is ...
Old 04-24-06, 02:43 PM   #1 (Link)
Alias: evan
Loc: ny
User: #23
evan is offline
sine waves
I downloaded the sine waves to a cd and on the 16hz and up to a few others there is a buzzing heard is this normal or was the disc or file bad when I got to around 60 and above it disappeared
Old 04-24-06, 02:56 PM   #2 (Link)
Loc: Lower Alabama
Re: sine waves
This is the first I've heard of any buzzing and those sinewaves have been there for several years and downloaded by thousands of people. But anything is possible.
Are you using them as mp3's or did you convert them to wave files?
Listen to them on your computer through Windows Media as mp3 files and see if you notice a buzzing. If so, try re-downloading one of the frequencies that's buzzing (preferrably a higher frequency than 16hz ... if one is buzzing around 50hz or so, use it). See if it still does it... if so let me know which one in particular and I'll see if something may be haywire on our side.
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
