| SPL Meters | Mic's | Calibration New RS SPL Meter Corrections are posted...Discuss New RS SPL Meter Corrections are posted... in the Subwoofer Equalization | Calibration forum; New RS SPL Meter Corrections are posted... We wanted all members to be aware that we have posted new RS SPL Meter Correction Values on the Downloads ... |
| | #1 (Link) | |||
| | New RS SPL Meter Corrections are posted... We wanted all members to be aware that we have posted new RS SPL Meter Correction Values on the Downloads page here at the Shack. The new values are from 7Hz to 200Hz. These new calibration files were calculated based on a comparison to my ECM8000 mic that has been calibrated and certified by West Caldwell Calibration Laboratories. We believe these will be the most accurate corrections available, short of having your RS SPL meter professionally calibrated. We have also created new Excel Workbooks for those that may be interested. The workbooks include new graph axis from 7Hz to 200Hz. These are also available from the Downloads page. Special thanks to brucek for all his work on this... ![]() | |||
| | #3 (Link) | |||
| Re: New RS SPL Meter Corrections are posted... I know I'm slow but are you saying to deduct or add those values to the meter reading we are getting. . .An example is at 20Hz you show -10 or whatever the actual number is. .Can't remember. . .What I see is if (say) you have your meter set on 80Hz and your SPL is reading 80Hz do you deduct from your meter reading for the actual SPL at that frequency if your correction numbers show a minus?? What I'm trying to do is get a quick and dirty reading when setting up my room. . .Just curious if you would set that 20Hz level higher or lower on the RS meter reading. . . Maybe I need to go to bed. . .I know I'm smarter than I appear right now. . . I always knew those meters were 'off' at the lower frequencys but never knew how to compensate for it. . . Mahr's Law of Restrained Involvement. Don't get any on you. . . | |||
| | #4 (Link) | ||||
| Re: New RS SPL Meter Corrections are posted... Quote:
brucek | ||||
| | #5 (Link) | ||||
Happy Easter. . . Mahr's Law of Restrained Involvement. Don't get any on you. . . | ||||
| | #7 (Link) | |||
| Re: New RS SPL Meter Corrections are posted... Thanks for the great software package! I can't seem to get the spl meter calibration file loaded into REW. When I browse to the file I downloaded (at the above link), and click 'OK' it tells me 'Not enough data values in the file'. Also, if I use this file, do I have to check the 'C weighted' box or does a loaded file contain the 'C' weighting? Help! Thanks Tom Edit, OK I'm an Idiot, I downloaded the .xls instead of the cal file. Oops! T | |||
| | #8 (Link) | ||||
brucek | ||||
| | #10 (Link) | |||
| Re: New RS SPL Meter Corrections are posted... Thanks to all concerned for the new cal files. ![]() In a desperate attempt to undermine your efforts I did some new traces using the new cal files. Green and mustard are my two RS meters old and new using the new cal file for old meters. I have a 3dB calibration difference between the two meters on pink noise but they track well on the response curves. The Galaxy 140 (C-unchecked) consistently reads lower output at about -32dB on SPL calibration. It shows falling output with falling frequency compared with the RS meters. 10dB discrepancy by 11Hz. Deliberately checking C-weighting makes it droop even further with falling frequency. I double checked that I reloaded the correct cal files after clearing each cal file. I checked on the graph that the correct cal curve was shown as well as the name appearing in the box under "Settings". I carefully checked I had C weighting cleared (or checked) as appropriate for each meter and matching cal file. I tried fast and slow on the Galaxy and carefully "calibrated SPL meter" to 75dB(C) in all cases. All 3 meters were orientated at right angles to the IB and fitted to the tripod at the listening position without moving the tripod. ![]() Any useful thoughts please? ![]() | |||
| | #11 (Link) | |||||||
brucek | |||||||
| | #12 (Link) | |||
| Re: New RS SPL Meter Corrections are posted... Because I get better bass from the RS meters. More seriously: I thought they should all track each other if I used the appropriate cal files. I posted my results to see if you agreed BTW: If I do check C-weighting using the Galaxy cal file and Galaxy meter then it really does make a difference to the response curve. It droops in the low bass. I'll save the graphs next time to prove it. ![]() | |||
| | #13 (Link) | ||||
brucek | ||||
| | #14 (Link) | |||
| Re: New RS SPL Meter Corrections are posted... Just wondering are the files for the 33-2055 Digital RS Meter and the 33-4050 Analog RS Meter supposed to be the same? I belive that you may have the Correction values for the Digital RS meter listed for both Analog and Digital. ![]() | |||
| | #15 (Link) | ||||
I am sure I saw a droop on one test when I checked C weighting. Now I can't replicate it. I have been following your advice and cutting back on the 20Hz boost filters. 30 sweeps later I'm getting there and the low test levels using the Galaxy are slowly rising. 2 x 20hz +3dB. Can't let Rodny win this one. IB reputations are at stake! ![]() Oh alright it's rubbish! Where's Steve Callas when you need him? Bwah! ![]() | ||||
| | #16 (Link) | ||||
brucek | ||||
| Thread Tools | |
Similar Threads | ||||
| SPL meter problems | nschneir | REW Forum | 2 | 03-06-07 07:43 PM |
| New SPL Meter... | Sonnie | SPL Meters | Mic's | Calibration | 14 | 01-23-07 05:30 AM |
| Digital spl-meter ok? | Gson76 | SPL Meters | Mic's | Calibration | 4 | 12-22-06 08:26 AM |
| My SPL meter might be broken... :( | Exocer | REW Forum | 13 | 09-06-06 02:19 PM |
| corrections for M-Audio and not enought SPL from REW | UNICRON-WMD | REW Forum | 7 | 08-05-06 08:53 PM |
