| SPL Meters | Mic's | Calibration | Sound Cards Macbook running Vista--Soundcard?Discuss Macbook running Vista--Soundcard? in the Subwoofer Equalization | Calibration forum; Macbook running Vista--Soundcard? Hey Shacksters,
I've got a Macbook (bought this summer--has 2.16ghz core 2 duo with 2 gig ram) and I'm running ... |
| | #1 (Link) | |||
| Hey Shacksters, I've got a Macbook (bought this summer--has 2.16ghz core 2 duo with 2 gig ram) and I'm running bootcamp in the Leopard OS for Vista. It's pretty cool being able to use the machine for the best of both worlds & now I'm wondering what I need to make this REW-ready. Last time I used REW it was with my HTPC and BruceK was totally helpful--he was way patient with me, I tell you! 1. Will REW work with Vista OS? 2. Does my Mac's SigmaTel High Definition Audio (in-board) card have the needed tech to work with the RS SPL meter? It has a "mic" input (the standard 1/8" plug next to the headphone jack). It also says it is an SPDIF input and calls it a "left panel optical jack" (though that must just be a naming game since there's no real "optical" as in fiber-optic jack on the side). I was browsing in the control panel to look at the sound card properties and noticed it has the ability to do room correction?! Is that just a software function of Vista, or is it detecting the SigmaTel soundcard capabilities? BTW, I have a BFD 1124 and am anxious to recalibrate since I've just added a new Yamaha 1800 avr and Sherbourn 5x200w amp! My previous avr could only x-over the sub at 90hz and with my mains that easily go into the 30hz range and my pb12+/2, I'm dying to x-over around 60hz! Thanks for any help here, Phil Dali Mentor 8/Vokal/Ikon Phantom 5.1; SVS pb13 Ultra; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Heaven! ![]() Now about that projector... | |||
| | #2 (Link) | |||||
| Re: Macbook running Vista--Soundcard? Quote:
brucek | |||||
| | #3 (Link) | |||
| Re: Macbook running Vista--Soundcard? Big thanks, BruceK! So, what's the most reasonable, but effective outboard soundcard? Any ideas of where to get it from? Thanks again, Phil Dali Mentor 8/Vokal/Ikon Phantom 5.1; SVS pb13 Ultra; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Heaven! ![]() Now about that projector... | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Running more than one sub on an Onkyo 805 | tonyvdb | Home Audio Subwoofers | 7 | 12-16-07 03:09 PM |
| Macbook pro problems | thxgoon | REW Forum | 13 | 11-07-07 11:12 PM |
| running speaker wires | bonj87 | Home Theater Design and Construction | 3 | 10-23-07 10:04 AM |
| Problem with Room EQ Wizard running Vista? | oajungen | REW Forum | 4 | 04-29-07 08:55 AM |
| Up and running.... | garymck | DIY Subwoofers | 4 | 07-26-06 10:44 AM |
