Galaxy CM-140 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration
Galaxy CM-140
Discuss Galaxy CM-140 in the Subwoofer Equalization | Calibration forum; Galaxy CM-140 Hi all Can enybody tell me if it is possible to turn down the output leavel on this spl meater, ...
Old 05-21-07, 10:11 PM   #1 (Link)
Alias: DREW
Loc: UK
User: #5502
Since: Jan 2007
drew01484 is offline
Galaxy CM-140
Hi all
as i am convinced that it is set far two high.
I'am just not getting anywhere in REW, i can do a soundcard cal just fine but when
i try to check levels i can not get the input level any lower than -5dB even if i mute
line input.
also i can not ger REW to controal my soundcard (using a Macbook pro with bootcamp and vista) so iam using vista's sound controls.
i have tryed pluging the headphone output from my tv into the input of my laptop to
see if the same happens, and it dosen't i' am able to get the input level to -18dB, so
this is why i think the output level is set two high on the CM-140.
Thanks in advance for any advice you can offer.
Drew...
Old 05-21-07, 11:46 PM   #2 (Link)
Alias: Nick
Loc: Seattle, WA
User: #7848
Since: Mar 2007
MakeFlat is offline
Re: Galexy CM-140
Be sure to connect to Line-in, not mic in. Also, you can turn down the speaker volume, so that lower SPL gets to the CM-140. Also, if you have a choice between 70dB scale vs 80 dB scale, choose 80dB scale on the CM-140 to see if that makes a difference.
Nick
Old 05-22-07, 08:06 AM   #3 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
Re: Galexy CM-140
Hi DREW,
Something else is up, you shouldn't need to reduce the CM-140's output; in fact, I don't think it's possible. Start with what Nick said, and let us know how it goes.
-- Otto
Old 05-22-07, 11:59 AM   #4 (Link)
Alias: DREW
Loc: UK
User: #5502
Since: Jan 2007
Re: Galaxy CM-140
Thanks u 2
What a compleat DONKEY I 'am
I'have bean trying for ages to sort this out
You was right it was the spl meter that was on 32-80 instead 50-100
just thought that as i neaded an in room spl of 75dB 32-80 would do the job.
Anyway thanks again
Drew......
Old 05-22-07, 12:09 PM   #5 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
Re: Galaxy CM-140
Changing the display range modified the output level of the meter?
-- Otto
Old 05-22-07, 01:28 PM   #6 (Link)
Alias: brucek
User: #6
brucek is online now
Re: Galaxy CM-140
Yes, same as any SPL meter...............
Old 05-25-07, 06:57 AM   #7 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
Re: Galaxy CM-140
brucek wrote: View Post
I just checked. REW reads the Galaxy output as 20dB lower using midrange and 40dB lower using high range.
Both levels are relative to the default low range.
Old 05-25-07, 08:33 AM   #8 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
Re: Galaxy CM-140
Yeah, I measured it too that night. Guess I'd never thought about it, and always used the mid range. I believe the reasoning behind it is that the user gets a better resolution for their particular measurement by having three ranges; the max and min outputs are relative to the range. It's akin to having a pad switch on a mic or preamp so that you are able to take advantage of the range that best fits your application. That's what I'm thinking anyway.
-- Otto
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration »
Similar Threads
Galaxy CM-140 SPL Meter Pre-Order Sonnie SPL Meters | Mic's | Calibration 175 06-06-08 12:11 PM
Galaxy CM-140 Calibration File Info Thread Sonnie SPL Meters | Mic's | Calibration 43 06-22-07 12:26 PM
Calibration – Cant get a Flat response ? CM-140 & DSP1124 & REW tapeshc REW Forum 8 04-10-07 09:52 PM
First Galaxy 140 results. Chrisbee REW Forum 28 04-05-07 01:37 PM
Mach 5 Audio
