Looking for "full-range" 33-2050 cal or txt file. - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration
Discuss Looking for "full-range" 33-2050 cal or txt file. in the Subwoofer Equalization | Calibration forum; Looking for "full-range" 33-2050 cal or txt file. What is the most current (and thought to be most accurate) "full-range" cal file for the 33-2050 meter and where ...
Old 06-07-07, 07:11 PM   #1 (Link)
Alias: whoaru99
User: #9426
Since: Jun 2007
whoaru99 is offline
What is the most current (and thought to be most accurate) "full-range" cal file for the 33-2050 meter and where may I find it?
Thanks.
PS: Did some searching and found only cal file for bass correction factors.
Old 06-07-07, 10:07 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Looking for "full-range" 33-2050 cal or txt file.
There is no full range correction file for the Radio Shack meters . They are inconsistent at higher frequencies. If you want to measure full range a good microphone for the job is the Behringer ECM8000 combined with a proper preamp.
burcek
Old 07-13-07, 08:22 AM   #3 (Link)
New Member
Alias: Tony
Loc: Montreal
User: #10092
Since: Jul 2007
distox is offline
Anyone know how high (frequency) you can go with the RS meter before the readings are no longer reliable?
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration »
Similar Threads
4" full range Speakers BoomieMCT DIY Speakers 25 02-26-08 05:21 AM
My sub goes "tock" when it should go "thud" BoomieMCT DIY Subwoofers 11 04-18-07 05:07 PM
Parsing Error Creating Make Cal file dbbarron REW Forum 1 03-24-07 09:14 PM
Full Range CD Danny Music and DVD Concerts 2 02-10-07 08:21 PM
REW Full-Range Features? Longfellowe REW Forum 4 06-02-06 03:30 AM
Mach 5 Audio
