Settings to use on Galaxy cm-140 (manual measurements) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Discuss Settings to use on Galaxy cm-140 (manual measurements) in the Subwoofer Equalization | Calibration forum; Settings to use on Galaxy cm-140 (manual measurements) I just bought a galaxy cm-140 and I'll be taking manual measurements as I do not have REW or access ...
Old 06-21-07, 05:01 PM   #1 (Link)
Alias: lexx2004
Loc: Buffalo
User: #9378
Since: Jun 2007
lexx2004 is offline
I just bought a galaxy cm-140 and I'll be taking manual measurements as I do not have REW or access to a laptop. I've noticed on some to the posts that individuals are advised to use the "fast" setting. Is that the case only if you're using REW? The general setting for measurements is usually "c weighting" and "slow" (at least with my analog RS meter, those were the settings).
Also, does REW provide users with what a frequency response should look like for a given crossover frequency setting? If so, can someone provide me with the responses for the following crossover settings..90 hz, 60 hz, 50 hz, and 40 hz. I'll need those for HT and music. Thanks for the help.
Old 06-21-07, 05:12 PM   #2 (Link)
Alias: brucek
User: #6
brucek is online now
Re: Settings to use on Galaxy cm-140 (manual measurements)
And those are the correct settings to use with the Galaxy also.
I can certainly do that, but it would be far easier and more useful to you to download REW and play with it yourself. You don't need to do response checks (or anything else) to simply look at the crossover targets. That way you can vary the filter slopes etc...
Old 06-22-07, 05:13 AM   #3 (Link)
Alias: Chrisbee
Chrisbee's Avatar
User: #33
Chrisbee is offline
The Galaxy uses a MONO mini jack socket instead of the phono (RCA) socket used on the RS meter.
Your PC doesn't need to be near the sub to run REW tests. Just use cheap, very long phono cables. Musical instrument shops sell long phono cables at very reasonable prices. I use two cables of 10 meters or 30 feet each. One from the SPL meter to my USB soundcard and the other from the soundcard to my stereo preamp. (no AVR)
Be very careful about setting calibration levels manually on your AVR or stereo preamp when using REW. I have to run backwards and forwards to set meter calibration levels on my stereo preamp volume control. Arranging the SPL meter at the listening position on a tripod so the display can be easily read helps. The meter has a tripod socket on the back just like the RS meter. I use a pan and tilt head to make adjustment simple. I have even used a small telescope to read the SPL meter from my PC when calibrating REW in poor light.
Old 06-22-07, 09:24 AM   #4 (Link)
Alias: lexx2004
Loc: Buffalo
User: #9378
Since: Jun 2007
lexx2004 is offline
Thanks for the quick reply guys.
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
Similar Threads
Galaxy CM-140 SPL Meter Pre-Order Sonnie SPL Meters | Mic's | Calibration | Sound Cards 179 10-01-08 10:59 PM
Galaxy CM-140 Calibration File Info Thread Sonnie SPL Meters | Mic's | Calibration | Sound Cards 43 06-22-07 12:26 PM
Galaxy CM-140 drew01484 SPL Meters | Mic's | Calibration | Sound Cards 7 05-25-07 08:33 AM
Lose EQ Correction Settings Between Measurements? YimminyNoodle REW Forum 4 04-30-07 11:30 PM
First Galaxy 140 results. Chrisbee REW Forum 28 04-05-07 01:37 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
