| SPL Meters | Mic's | Calibration Behringer ECM8000 / SMS-1 micDiscuss Behringer ECM8000 / SMS-1 mic in the Subwoofer Equalization | Calibration forum; Behringer ECM8000 / SMS-1 mic I have a Velodyne SMS-1 parametric EQ that comes with a microphone that looks just like the Behringer ECM8000. Is ... |
| | #1 (Link) | |||
| Behringer ECM8000 / SMS-1 mic I have a Velodyne SMS-1 parametric EQ that comes with a microphone that looks just like the Behringer ECM8000. Is it the same microphone and can I accuratly use the Velodyne microphone with the calibration file for the ECM8000? For a mic preamp, I ordered the AudioBuddy. | |||
| | #2 (Link) | ||||
| Re: Behringer ECM8000 / SMS-1 mic Quote:
brucek | ||||
| | #3 (Link) | |||
| Re: Behringer ECM8000 / SMS-1 mic I ran a comparison of 3 microphone setups. It appears that the microphone that comes with the Velodyne SMS-1 is designed to significantly roll off after 1000Hz, so it must be a modified ECM8000. However, since I have yet to have a microphone calibrated, I don’t know which curve is closest to being accurate. microphone comparison.jpg RED Radioshack Digital meter REW C Weight checked RADIOSHACK-33-2055_4050.cal (HTS posted correction file) Laptop 48 Soundcard.cal (specific to my soundcard) GREEN Velodyne SMS-1 Microphone REW C Weight UNchecked newecm.cal (HTS posted correction file for Behringer ECM8000) Laptop Soundcard w Audiobuddy.cal (specific to my soundcard with Audiobuddy mic preamp/phantom supply) BLUE AudioControl RTA 3050 Microphone REW C Weight UNchecked No Microphone Calibration File Laptop Soundcard w Audiobuddy.cal (specific to my soundcard with Audiobuddy mic preamp/phantom supply) My guess is that the Blue line for the AudioControl microphone is closest to being accurate. I have created a correction file for the AudioControl microphone that closely matches the SMS-1 response with the newecm.cal file, so the low ends now match. | |||
| | #4 (Link) | ||||
brucek | ||||
| | #5 (Link) | |||
| Re: Behringer ECM8000 / SMS-1 mic Notice above that the calibration file I used in the green and blue graphs includes the soundcard and the Audiobuddy preamp, whereas the calibration file for the measurement with the RS meter only includes the soundcard. | |||
| | #6 (Link) | |||
| Re: Behringer ECM8000 / SMS-1 mic Ah, Ok, good stuff. So, why do you feel the AudioControl RTA 3050 Microphone is the accurate one? I see you're using no calibration for it. Is it a particularily high quality mic that is actually flat from 15Hz to 20Khz? brucek | |||
| | #7 (Link) | |||
| Re: Behringer ECM8000 / SMS-1 mic I found the below in an AudioControl Owner's manual for a product that used the same CM-10microphone. I created a calibration file that resembles this plot and I think I'll be +/- 1dB from 20-20K -- good enough for Shack work! CM-10 FR data.JPG | |||
| | #8 (Link) | |||
| Re: Behringer ECM8000 / SMS-1 mic Great. I guess you realize the REW mic cal files are negative values when the response of the mic is negative, so the file you should use would look like this. 20 -1.5 100 -0.5 8000 +1.5 20000 -2.0 brucek | |||
| | #9 (Link) | |||
| Re: Behringer ECM8000 / SMS-1 mic Attached is my .cal file in case anyone wants to give it a try. I just EQed my subs with it and it sounds awesome! AudioControl CM-10 Microphone.cal | |||
| | #10 (Link) | |||
| Re: Behringer ECM8000 / SMS-1 mic For anyone who is still interested I contacted Velodyne a while ago asking them this specific question and was told that the SMS-1 Mic is a rebadged version of the ECM8000. So if I was told the truth they are the same mic. | |||
| | #11 (Link) | |||
| Re: Behringer ECM8000 / SMS-1 mic avaserfi, I think the operative word is "version" of the ECM8000. It appears that starting at 800Hz, the SMS-1 mic rolls off steadily to about -20db by 20kHz. They must have put a capacitor in there to limit the high end sensitivity since it used only for low freq. measurements. However, below 800Hz, it does appear to measure like the the ECM8000. I am having my CM-10 mic calibrated and I'll compare it to my SMS-1 mic and post results (may be several weeks from now). | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| Behringer FBQ2496 / Velodyne SMS-1 distortion | Ilkka | BFD Forum | 71 | 07-12-08 08:06 PM |
| Behringer ECM8000 still the one to get?? | JimP | SPL Meters | Mic's | Calibration | 52 | 07-16-07 01:00 AM |
| preamp for Behringer mic comparison--which should I keep??? | JimP | SPL Meters | Mic's | Calibration | 21 | 06-26-07 10:46 AM |
| Behringer ECM8000 Mic | Peter De Smidt | SPL Meters | Mic's | Calibration | 10 | 05-20-07 06:14 PM |
| Behringer ECM8000 Mic. Question. | srbaker | SPL Meters | Mic's | Calibration | 5 | 06-07-06 02:52 AM |
