Cable problems - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Cable problems
Discuss Cable problems in the Subwoofer Equalization | Calibration forum; Cable problems looking at buying a Behringer XENYX 802 and Behringer ECM8000 from PE for measurement purposes.. only problem, i cant find ...
Old 11-10-07, 11:03 AM   #1 (Link)
Alias: Kerazul
User: #13241
Since: Nov 2007
Kerazul is offline
Cable problems
looking at buying a Behringer XENYX 802 and Behringer ECM8000 from PE for measurement purposes.. only problem, i cant find a suitable cable on there.. there's a nifty 20ft 1/4" "guitar" cable that looks like it would work, and a 1/4" to 3.5mm mono adaptor.. great right? wrong.. there's no way that thick plug would fit on my x-fi, the line in/mic input is right beside the main speaker out jack.
any suggestions? otherwise i guess i have to look around locally.. which might not result in much, especially with CC buying out radio shack and all
Old 11-10-07, 12:19 PM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: Cable problems
Here's an entire page full of them at Parts Express... pick your poison!
Welcome to the Shack!
Sonnie
Old 11-10-07, 12:24 PM   #3 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Cable problems
Remember that a soundcards line-in is a stereo plug.
You need a stereo to mono adapter at the soundcard to 'break out' the left and right channel of the line-in to the soundcard. The single plug end is stereo and the Y-plug ends are mono.
This type of adapter is what I'm referring to and it would fit fine into any soundcard.
Now you can use a 1/4" TS phono to RCA, which is a standard cable. Then get a simple RCA to 3.5" coupler to hook to either the left or right channel of the Y-cable above... Maybe you could even find a Y-cable that had RCA's on the Y-plug ends.
Old 11-10-07, 09:33 PM   #4 (Link)
Alias: Kerazul
User: #13241
Since: Nov 2007
Kerazul is offline
Re: Cable problems
hmm.. complicated i'll just do what i always do when i cant find a cable that works, cut and patch 2 together
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
Similar Threads
DIY Cable and Cable Tools Sonnie Remotes | Cables | Accessories 1 02-22-08 10:20 PM
Z3 problems... Rodny Alvarez Home Theater Projectors 2 10-15-07 08:07 AM
Has anybody bought cables from Signal cable or Colbolt cable??? Jay C Huskers Remotes | Cables | Accessories 0 02-04-07 11:28 AM
Good Sub Cable w/Cheap Y-Cable... Lose Quality? baniels Remotes | Cables | Accessories 4 12-07-06 10:22 AM
Remote Problems. alan monro Remotes | Cables | Accessories 1 06-20-06 01:28 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
