How to... - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration
How to...
Discuss How to... in the Subwoofer Equalization | Calibration forum; How to... I just purchased B&W speakers. The 804 series. I have the 990/7700 combo from Outlaw. I recently bought the JL ...
Old 11-18-07, 04:06 PM   #1 (Link)
Alias: frank
Loc: folsom pa
rubbersoul's Avatar
User: #13320
Since: Nov 2007
rubbersoul is offline
How to...
I just purchased B&W speakers. The 804 series. I have the 990/7700 combo from Outlaw. I recently bought the JL Audio Fathom 113 subwoofer two weeks ago. (still waiting for it to come in)
Questions about calibration.
What is recomended and what I think I will do is use the 990 since it has it's own calibration system that comes with a good mic that has a good running length cord. Measuring first the distance of all of my speakers and entering them into the 990, then use the automatic calibration.
I was going to select none for the subwoofer since the Fathom 113 has it's own calibration system. Once my mains and surrounds and rear center are calibrated I was going to calibrate the sub with it's own system.
Is this what I should be doing? Is there more that I should be doing? Do I need an SPL meter? I am not familar with the systems on this site to calibrate a sub and therefore a little nervous about what I am reading on the forum.
Old 11-18-07, 04:10 PM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is offline
Re: How to...
Hi frank.
I used to have a 990. I would probably skip the auto-setup, and go for the SPL meter. The auto-setup can sometimes get confused -- I've had it think that I didn't have some speakers, and it set other levels kind of weird. I still used the 990's internal tone generator (and sometimes the AVIA test disc), but the meter will be more accurate. It will also be much more useful for "other" stuff you may wish to do in the future. I'd suggest the Galaxy meter (CM-140, I believe), but the RS meter will also work.
Good luck!
-- Otto
Old 11-18-07, 06:06 PM   #3 (Link)
Alias: frank
Loc: folsom pa
rubbersoul's Avatar
User: #13320
Since: Nov 2007
Re: How to...
Thanks Otto, I never heard of the Galaxy. Online item?
By the way LOVE COLORADO
Old 11-18-07, 06:17 PM   #4 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is offline
Re: How to...
Hi frank,
Yeah, the Galaxy can be ordered online here, and probably other places. Sonnie (HTS owner) did a group buy a while ago, so a lot of us have them...
Yeah, Colorado is beautiful! I do enjoy getting out to PA every once in a while myself -- my wife's parents live out there somewhere -- Altoona!
Have a good night.
-- Otto
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration »
Mach 5 Audio
