Go Back   Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration
Register
Soundcard calibration
Discuss Soundcard calibration in the Subwoofer Equalization | Calibration forum; Soundcard calibration Hi all, I'd like to begin with a thank you; for providing some of the most knowledgeable and informative reading ...
Old 12-16-07, 10:14 AM   #1 (Link)
Alias: Conrad
Loc: London
User: #3578
Since: Oct 2006
Conrad. is offline
Hi all,
I'd like to begin with a thank you; for providing some of the most knowledgeable and informative reading about sub equalization that I've read. Some of it I've even understood!
I’ve probably done things in the wrong order but I have a BFD and an analogue Radio Shack SPL meter on order to help me EQ a pair of Velodyne SPL1000s on the basis that EQing will improve things.
I’ve read through the stickies, guides and help files and I think I’ve got a rough idea about what to do when everything arrives (although no doubt I’ll be posting graphs and asking more questions/for help when they’re here) but I have an initial question about soundcard calibration.
My PC has an RME soundcard in it that sends a 5.1 signal to my receiver’s multi-channel inputs. These are then passed from the pre-outs to the power amp; apart from the sub, that goes direct from the receiver to the subs with a simple y-cable. I also have SPDIF from the sound card to the receiver so that I can use the receiver to process 2.0 signals into PLII. My PC also has onboard 7.1 audio which I could use.
My question is what output should I connect to what input for the loopback calibration? I’m pretty sure I want to use the RME over the onboard just because of the quality. I’m also pretty confident that I don’t want to use SPDIF out to SPDIF in (although would that work?). Also, as I’m only sub EQing should I just connect the sub out from the soundcard to the line in? I don’t even know if REW can see the RMEs individual channels so I might be consigned to using onboard.
I’m going to have to do a lot of playing around and testing but peoples initial thoughts would be nice to hear.
Apologies for the long first post and for falling quite so spectacularly at the first hurdle; thanks again!
Conrad
Old 12-16-07, 10:20 AM   #2 (Link)
Friend of the Shack
Alias: Otto
Loc: Beautiful Colorado
Otto's Avatar
User: #625
Otto is online now
Re: Soundcard calibration
Hi Conrad, and welcome to the Shack!
Yeah, you will just go analog out of your sound card to the appropriate input on the receiver/preamp. Usually, we just use the stereo output of the soundcard, as it's the simplest method. If you go into a left or right input on your preamp (instead of a sub input), you will also be able to measure the response of the sub and mains together (though that will come after the sub calibration by itself). Also, I'm pretty sure REW is going to want to work with a stereo output (defaults to left), so it may not know how to handle a 5.1 output on your RME soundcard.
Since you'll probably have to go stereo out to the preamp, just do the loopback in the same fashion. Soundcard "line out" to soundcard "line in." Don't use "mic in." Do the soundcard cal, and go from there.
Good luck, you're on the right path.
-- Otto
Old 12-16-07, 10:43 AM   #3 (Link)
Alias: Conrad
Loc: London
User: #3578
Since: Oct 2006
Conrad. is offline
Excellent, thanks for that. I've just had a quick check and I can choose which pair of channels I want to output the signal over. I guess for soundcard calibration I'll go for 1+2 - main L+R - with the input on the matched pair (I have 6 outputs with 2 inputs). When it comes to actually performing the sweeps I'll send everything out of the 3+4 channels - sub and center.
Now, I already have another question!
As I explained, I have a pair of subs (not co-located). Currently they're running from a single LFE output on my receiver; I also understand that the BFD supports two channels. In terms of connections, should I just run one channel into the BFD, split the output and EQ them as a single sub (they’ll always be on at the same time) or should I split the signal before the BFD and then EQ then separately?
Sometimes it’s nice to have so much flexibility but then sometimes an absolute would be a real relief!
Old 12-16-07, 02:08 PM   #4 (Link)
Friend of the Shack
Alias: Otto
Otto's Avatar
User: #625
Otto is online now
Hi Conrad,
It's frequently recommended to EQ two subs at the same time. So, yeah, go to the BFD with the sub out of your preamp, and then split the output of the BFD. That way, you will EQ everything for the room as one. If you EQ one and then the other, such that each individual response is flat, it doesn't mean that it will necessarily be flat when you turn them both on. Of course, there's no harm in experimenting with using one channel of the BFD for each sub.
-- Otto
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration »
BB code is On, Smilies are On, [IMG] code is On, but HTML is not allowed!
Similar Threads
E-MU 1616M soundcard calibration help needed. Frank_S REW Forum 24 12-04-07 04:41 PM
soundcard calibration, what am I doing wrong. frezog REW Forum 20 09-26-07 08:28 PM
SB Live External soundcard calibration not working daxie REW Forum 3 01-24-07 01:38 AM
soundcard calibration check. terry j REW Forum 0 11-17-06 10:44 PM
Soundcard Calibration? Ross Winn REW Forum 2 08-22-06 07:21 AM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183
