Macbook running Vista--Soundcard? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration
Discuss Macbook running Vista--Soundcard? in the Subwoofer Equalization | Calibration forum; Macbook running Vista--Soundcard? Hey Shacksters, I've got a Macbook (bought this summer--has 2.16ghz core 2 duo with 2 gig ram) and I'm running ...
Old 12-17-07, 11:48 AM   #1 (Link)
Alias: Phil
Loc: Idaho
allredp's Avatar
User: #6382
allredp is offline
Question Macbook running Vista--Soundcard?
Hey Shacksters,
I've got a Macbook (bought this summer--has 2.16ghz core 2 duo with 2 gig ram) and I'm running bootcamp in the Leopard OS for Vista.
It's pretty cool being able to use the machine for the best of both worlds & now I'm wondering what I need to make this REW-ready.
Last time I used REW it was with my HTPC and BruceK was totally helpful--he was way patient with me, I tell you!
1. Will REW work with Vista OS?
2. Does my Mac's SigmaTel High Definition Audio (in-board) card have the needed tech to work with the RS SPL meter? It has a "mic" input (the standard 1/8" plug next to the headphone jack). It also says it is an SPDIF input and calls it a "left panel optical jack" (though that must just be a naming game since there's no real "optical" as in fiber-optic jack on the side).
I was browsing in the control panel to look at the sound card properties and noticed it has the ability to do room correction?! Is that just a software function of Vista, or is it detecting the SigmaTel soundcard capabilities?
BTW, I have a BFD 1124 and am anxious to recalibrate since I've just added a new Yamaha 1800 avr and Sherbourn 5x200w amp! My previous avr could only x-over the sub at 90hz and with my mains that easily go into the 30hz range and my pb12+/2, I'm dying to x-over around 60hz!
Thanks for any help here,
Phil
Dali Mentor 8/Vokal/Ikon Phantom 5.1; SVS pb13 Ultra; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Heaven!
Now about that projector...
Old 12-17-07, 02:03 PM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Macbook running Vista--Soundcard?
Yeah, REW works with VISTA, but I understand the audio mixer access is a bit fussy, but members have reported success.
You require a line-in connection (that most laptops simply don't offer). The solution everyone uses is an inexpensive external USB soundcard with standard line-in and line-out...... mic-in in is not suitable (nor is digital)....
Old 12-17-07, 02:15 PM   #3 (Link)
Alias: Phil
Loc: Idaho
allredp's Avatar
User: #6382
allredp is offline
Big thanks, BruceK!
So, what's the most reasonable, but effective outboard soundcard? Any ideas of where to get it from?
Thanks again,
Phil
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration »
Similar Threads
Running more than one sub on an Onkyo 805 tonyvdb Home Audio Subwoofers 7 12-16-07 03:09 PM
Macbook pro problems thxgoon REW Forum 13 11-07-07 11:12 PM
running speaker wires bonj87 Home Theater Design and Construction 3 10-23-07 10:04 AM
Problem with Room EQ Wizard running Vista? oajungen REW Forum 4 04-29-07 08:55 AM
Up and running.... garymck DIY Subwoofers 4 07-26-06 10:44 AM
Mach 5 Audio
