SMS-SVS Advice - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration
SMS-SVS Advice
Discuss SMS-SVS Advice in the Subwoofer Equalization | Calibration forum; SMS-SVS Advice Hi Guys, I am kind of a newbe to Sub Eq, I am running a pair of Maggie 1.6's and ...
Old 04-28-08, 08:14 AM   #1 (Link)
Alias: Beek
Loc: NYC
beek's Avatar
User: #3395
Since: Oct 2006
beek is offline
SMS-SVS Advice
Hi Guys,
I am kind of a newbe to Sub Eq, I am running a pair of Maggie 1.6's and SVS 20-39CS+ and the Velo. SMS latest ver. software in a 30X12.5X8 Ft. room with the sys. 1/3 way on the long wall (WAF). I measure at ear height at the sweet spot & get everything pretty flat except as I approach the rack the bottom end gets very fat & loud. There is some absorption outside the left * right of the Sys. with Room Tunes & a ASC 1/2 round center stage. Other Equip. Bel Canto amps, Crown K-1, Proceed Pre. Should I measure with Mg 1.6's Off? or a diff. mike placement? Any help would be really appreciated..................Bill
Old 04-28-08, 10:08 AM   #2 (Link)
Loc: Lower Alabama
Sonnie is offline
Re: SMS-SVS Advice
If I am understanding you correctly, every thing is fine at the sweet spot.
If that is the case, no need to do anything. Your goal is to get it sounding as good as possible at the sweet spot, since that is where you sit most of the time. It will be expected to not have nearly as good a response in other locations.
Sonnie
Old 04-29-08, 07:38 AM   #3 (Link)
Alias: Beek
Loc: NYC
beek's Avatar
User: #3395
Since: Oct 2006
beek is offline
Re: SMS-SVS Advice
Thanx Sonnie,
How about multiple miking & averaging the readings does that make much difference?
Old 04-29-08, 09:32 AM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
Re: SMS-SVS Advice
Yeah, REW has an averaging feature that allows you to create a new averaged response from multiple measures and then apply filters to that average... The result is an OK result at all the positions measured, rather than a single sweet spot. That's the beauty of a BFD with its multiple storage slots, is that you can have one set of filters for a sweet spot and another for the larger area.
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration »
Similar Threads
WTB---sms-1 pietsch288 Classifieds - Audio Equipment 1 03-20-08 07:41 PM
WTB---sms-1 pietsch288 Classifieds - Equalization and Calibration Equipment 0 02-03-08 11:27 AM
SMS-1 Question Vaughan100 BFD Forum 70 10-07-07 12:51 AM
FS: Velodyne SMS-1 Josuah Classifieds - Equalization and Calibration Equipment 0 12-01-06 11:04 PM
BFD v SMS-1 russ.will BFD Forum 15 09-10-06 12:19 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193
