Why not Radio Shack for full scale measurements? - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards
Discuss Why not Radio Shack for full scale measurements? in the Subwoofer Equalization | Calibration forum; Why not Radio Shack for full scale measurements? Hi All, Sorry if this has been asked before, I did a search and couldn't find the answer. Is it ...
Old 02-11-08, 05:39 AM   #1 (Link)
New Member
Alias: Albert
Loc: Germany
User: #15979
Since: Jan 2008
mkoijn9 is offline
Is it because the correction file doesn't go to full scale?
thanks
Albert
Old 02-11-08, 07:20 AM   #2 (Link)
Alias: brucek
User: #6
brucek is offline
Re: Why not Radio Shack for full scale measurements?
No, the Radio Shack meters simply aren't accurate at higher frequencies.
Old 02-11-08, 12:22 PM   #3 (Link)
New Member
Alias: Albert
Loc: Germany
User: #15979
Since: Jan 2008
mkoijn9 is offline
Thanks a lot for Quick reply, I will invest in a better meter or measurement mic
Albert
Old 02-11-08, 12:58 PM   #4 (Link)
Alias: brucek
User: #6
brucek is offline
The GALAXY CM-140 is your best bet. Or a Behringer ECM8000 microphone with a XENYX 802 preamp.
Old 02-11-08, 06:14 PM   #5 (Link)
Alias: GollyJer
User: #16465
Since: Feb 2008
GollyJer is offline
brucek wrote: View Post
bruce, do you have experience with both? I just ordered the behringer combo but am now thinking the Galaxy would be better simply because it's smaller and consists of one piece instead of two.
Old 02-11-08, 06:56 PM   #6 (Link)
Alias: brucek
User: #6
brucek is offline
Well, I own the ECM8000 and 802 combination, and its only shortcoming is that you require a cheap SPL meter to initially set the SPL level in the room to match REW's meter. This means it's quite expensive for someone who starts out with nothing and has to buy all the gear.
But you have a cheap SPL meter, so I would recommend the ECM and 802 preamp. It's a better microphone and its balanced output allows for a long cable to be used to connect it to the preamp. The Galaxy is only an unbalanced output.
The 802 preamp also allows you quite a range of output voltage, where the Galaxy is a fixed output.
Old 02-11-08, 07:07 PM   #7 (Link)
Alias: GollyJer
User: #16465
Since: Feb 2008
GollyJer is offline
Sounds good. I guess I won't cancel the order.
Now I just need to find out why output voltage matters. :P
Old 02-11-08, 07:32 PM   #8 (Link)
Alias: brucek
User: #6
brucek is offline
Some people find that they don't have enough level into their soundcards line-in jack to satisfy it properly. It's nice to be able to simply turn it up if you need it.......
« Home Theater Shack > Subwoofer Equalization | Calibration > SPL Meters | Mic's | Calibration | Sound Cards »
Similar Threads
Radio Shack 33-4050 v1rtu0s1ty SPL Meters | Mic's | Calibration | Sound Cards 11 02-02-08 07:43 PM
Full Range Measurements with REW - What Equipment? Drizt REW Forum 19 07-21-07 11:50 PM
Full range measurements rcarlton Home Audio Acoustics 7 07-05-07 06:49 AM
Old Radio Shack SPL cal Testpattern SPL Meters | Mic's | Calibration | Sound Cards 13 07-04-07 06:19 PM
accuracy of REW for full range measurements? terry j REW Forum 8 11-18-06 05:00 AM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194
