| SPL Meters | Mic's | Calibration Best USB sound and midi module including Phantom mic input !Discuss Best USB sound and midi module including Phantom mic input ! in the Subwoofer Equalization | Calibration forum; Best USB sound and midi module including Phantom mic input ! You have a line level RCA out which you would want to route to a balanced mic level in.
Oh, ... |
| | #51 (Link) | ||||
| Re: Best USB sound and midi module including Phantom mic input ! Quote:
brucek | ||||
| | #52 (Link) | ||||
After thinking about it for a while, I think I can do it with my DCX. I can go into the behringer with the RCA to XLR cable, then go out (no filters) balanced to the mic in. I can also come out of the behringer to an unbalanced line in to control for the response errors of the DCX. I know the behringer can handle unbalanced inputs and both balanced and unbalanced output so that just might do the trick. I am sure you could also make a relatively simple circuit board to convert the unbalaced out to balanced but I am not sure if that would introduce any significant error. All this to get a precise measurement at 6 or 7 hz where no EQ I know of can be used to tune the signal anyway ![]() | ||||
| | #53 (Link) | |||
| Re: Best USB sound and midi module including Phantom mic input ! Another similar product, just as an option, with MIDI support and phantom mic power is the E-MU 0404USB. This product has reference quality measured behaviors(s) to boot, as verified by [1]3rd party measurements. In addition, the 0404USB device can be used without a computer as high quality stand-alone mic-preamp and/or ADC or DAC, with both coaxial and optical digital I/Os. -Chris Footnotes [1]E-MU 0404 USB - A Top-Class External Audio Interface http://www.digit-life.com/articles2/...-0404-usb.html | |||
| | #54 (Link) | |||
| Re: Best USB sound and midi module including Phantom mic input ! The ART dualPre looks like it could also be an economical option for a soundcard/mic preamp with phantom power, though it does not have any midi features. With independent left/right input gains it would allow straightforward line level loopback for the reference channel. The "monitor" outputs carry the signal from the PC/Mac when the mix knob is turned fully to the "Computer" position. http://www.sweetwater.com/store/detail/USBDualPre | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| E-Mu 0404 USB with Phantom Power for ECM8000 | Stealthlude | SPL Meters | Mic's | Calibration | 8 | 04-27-08 01:01 PM |
| PS3 Compatible Headset (including mic) | lspence | Computers | Games | HTPC | Digital Devices | 1 | 12-27-07 02:58 PM |
| Vista and Edirol UA1-EX: Sound from mic (input) is being sent to output, bad results | goatwuss | REW Forum | 2 | 10-12-07 01:46 PM |
| USB to MIDI interface... | aceinc | REW Forum | 3 | 03-03-07 08:59 PM |
| DIY Midi to USB cable | GaryK | BFD Forum | 6 | 04-21-06 02:47 PM |
