| Subwoofer Tests - Archived LMS-5400 buy-inDiscuss LMS-5400 buy-in in the Manufactured Speakers and Subwoofers forum; LMS-5400 buy-in Lookin good Illka! I think you should tune that sucka as low as is reasonable. Maybe you can try it ... |
| Alphabetical Search | |||||||||||||||||||||||||||
| All | # | A | B | C | D | E | F | G | H | I | J | K | L | M | N | O | P | Q | R | S | T | U | V | W | X | Y | Z |
Views: 24371 - Replies: 311
| | #226 | ||||
| Re: LMS-5400 / RL-p18" buy-in Lookin good Illka! I think you should tune that sucka as low as is reasonable. Maybe you can try it with 2 tunings, one around 16 and the other one lower, if it will go without exceeding the PR's mass abilities? | ||||
| | #227 | ||||
| Re: LMS-5400 / RL-p18" buy-in 16Hz sounds good. What HP filter do you plan to use? Those crowns look great. Did you get a chance to mod the fans? | ||||
| | #228 | |||||
| Re: LMS-5400 / RL-p18" buy-in Quote:
| | #229 | |||||
| Re: LMS-5400 / RL-p18" buy-in 2nd order BW at 16 Hz. Quote:
| | #231 | |||||
![]() P.S. With 4 Crown CE4000 - it's enough poweh to clip anybodies wings! ![]() Last edited by Klip; 10-05-07 at 07:56 PM.. | |||||
| | #232 | |||||
if your driver bottomed out. | |||||
| | #233 | ||||
| Re: LMS-5400 / RL-p18" buy-in 2000 grams is fine and they were designed to take up to 2500gms. Those PRs have very robust components. I would still keep it below 2000. So 16Hz is the sweet spot. | ||||
| | #234 | |||||
Man Ilkka, I simply cannot wait to see the results. You are getting me very anxious, happy and nervous and the best word to describe this is anticipation. So please make it happen soon ![]() | |||||
| | #235 | |||||
| | #236 | |||||
I don't recall that. If so, maybe I didn't update on forums. But as my memory recalls, anything below 20Hz 2nd order was unsafe. Can you point me where I said that so I can go and update. | |||||
| | #237 | |||||
I don't recall you ever having a problem with the SSF set to 15Hz. I just thought you were afraid of potential problems at that setting so you set it higher. | |||||
| | #238 | |||||
At one time while measuring the THX intro scene, it was about +6dB beyond reference and there was a mild bottom out and thankfully that did not damage anything. So I switched back to 20Hz and since, I have not experienced any bottoming out. My fear of the potential problem was true though. Post #310 in my thread on avs talks about this 20Hz setting when I registered 119dB at LP. But the fact is, it did bottom out when the HP filter was set to 16Hz for the THX exploding ball scene. I hope this clears up some confusion. I had revisited WinISD models at that time and 16Hz 2nd order BW did show some warning signs with the peak excursion of the main driver. Blame it on the crown , it doesn't stop delivering . | |||||
| | #239 | ||||
| Re: LMS-5400 / RL-p18" buy-in What's with all this concern over bottoming the LMS 18 below 20hz.....especially in such a small enclosure? As LLT owners have been showing for some time now - most with only 15" drivers - you'd really have to be asking for trouble to get one to bottom. Keep a lowish tuning and make the enclosure smaller like Ilkka is doing, and you get even more protection. You loose low end sensitivity, but you can't have it all if staying so small. If the LMS is bottoming with a 16hz tune and 16hz highpass, then I'd look to the claimed xmax capabilities. Ilkka, what will the final enclosure volume be? 16hz tuning with a 16hz highpass seems like a bit of a waste of potential with these drivers to me. I highly doubt you will be listening at 130db+ levels, so trade some headroom for extension. | ||||
| | #240 | ||||||
| | #241 | ||||
| Re: LMS-5400 / RL-p18" buy-in Even if we assume the Crown amp has infinite power capabilities, I still look back to the TC2k tested outdoors at 2m with 2000 watts on a 115db sweep down to 10hz with no highpass and no bottoming or other mechanical driver issues. I'd hope an 18" with higher rated excursion capabilities from the same company could at least do that at 6db louder at all frequencies. | ||||
| | #242 | ||||
| Re: LMS-5400 / RL-p18" buy-in I definitely understand where you are coming from. But that scenario and Jai's situation really can't be compared directly. But there is no need for speculation when Ilkka himself will be fully testing the 5400 in a very similar alignment using a practically identical power setup. His observations and findings will be be more conclusive, wouldn't you say? | ||||
| | #243 | ||||
| Re: LMS-5400 / RL-p18" buy-in Absolutely. But I still say he shouldn't have to tune at 16hz with a 16hz highpass - wasted potential. | ||||
| | #244 | |||||
I too think he should be able to use maybe a 13Hz 2nd order BW, at least judging from the simulations. | |||||
| | #245 | |||||
| | #246 | ||||
| Re: LMS-5400 / RL-p18" buy-in All that I am saying is, start with 20Hz and then go lower. Proceed with caution. I have seen it happen and it is not pretty. 13Hz 2nd order BW? no I don't think so. Not with this design and tuning. His tests will tell. | ||||
| | #247 | |||||
| | #248 | ||||
| Re: LMS-5400 / RL-p18" buy-in If you are absolutely certain, and other owners are as well, then there is something amiss with this driver. There are quite a few of us LLT owners out there, and we use larger enclosures with low tunes, no highpass filters, and drivers that are supposed to have less excursion capabilities than the LMS 18, and there hasn't been bottoming yet, not with real material. Now I really want to see this design tested. Also, I agree that the difference between reproduction of material at 20hz and 16hz will be extremely hard to notice, however, being flat and solid to 10hz as compared to 20hz is a different story. | ||||
| | #249 | |||||
Perhaps what this driver can do that others can't is reproduce 10hz to 20hz flat, solid, AND LINEAR with less distortion. The long stroke and unique motor design allow the LMS to operate loud, low, and linear. The maximum spl of the LMS driver at a given FR depends on the particular application. The long stroke and unique motor design allow the LMS cone to easily move to it's XMAX because of the length and strength of the magnetic field produced by the huge magnet structure. I haven't seen another driver with a magnet structure as large as the LMS. Ilkka's upcoming full series of tests will answer most of our questions about the LMS and it's behaviour in-box. No more need to speculate or extrapolate from software modeling programs. Hang on Steve. | |||||
| | #250 | |||||
