Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived
LMS-5400 buy-in
Discuss LMS-5400 buy-in in the Manufactured Speakers and Subwoofers forum; LMS-5400 buy-in Ilkka wrote: It is an interesting topic of discussion, but the method you described isn't (IMHO) very good nor give ...
Alphabetical Search
All # A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
 Closed Thread     Post New Thread
Views: 24592 - Replies: 311
Old 10-08-07, 03:03 PM   #276
Alias: Jai
Loc: Portland, OR, USA
User: #7066
  jmcomp124 is offline
Re: LMS-5400 / RL-p18" buy-in
Ilkka wrote: View Post
It is an interesting topic of discussion, but the method you described isn't (IMHO) very good nor give accurate and consistent/comparable results. I will promise to ponder this issue a little bit further when I have finished with these current results. One thing is certain though: I will not take any new measurements until next spring/summer. Basically the weather just doesn't allow it.
The method I described is pretty crude and needs to be refined. It was only to convey the idea so it will get you to think along those lines. I have some ideas on how we can refine it. We can discuss this off-line.
Forum Rules
Old 10-09-07, 07:00 AM   #277
Alias: Joe
Loc: Johnstown, PA
User: #6535
  jpmst3 is offline
Thanks for those tests!
I love my LMSs/CEs even more now! (not that I needed a test to validate what I feel) Whoooohooo!
Forum Rules
Old 10-09-07, 08:10 AM   #278
Alias: Shervin
ssabripo's Avatar
Loc: Florida
User: #3688
Since: Nov 2006
  ssabripo is offline
Oh but wait. Good performance on objective measurements doesn't mean anything because they can not tell anything how the subwoofer sounds and feels subjectively. It can sound absolute even though measures great, and vice versa.
And a single number (or max two) is all you need to define how good a subwoofer is.
Forum Rules
Old 10-09-07, 08:59 AM   #279
Weasel
Inactive
Alias:
User: #
Posts: n/a
Ilkka,
Thank you for posting the specs on your boxes. Now I'll patiently await the test results.
Forum Rules
Old 10-09-07, 12:02 PM   #280
Alias: PHIL
ISLAND1000's Avatar
Loc: SHERMAN, TX
User: #8655
Since: May 2007
  ISLAND1000 is offline
I noticed after purusing the photos that the LMS driver is mounted using the rubber gasket and the PRs look as though they are not. Do you think the gasket allows a good solid mechanical hookup to the baffle? Did the PRs come with a gasket? Do you think the specified bolts are sufficient for mounting the driver?
I guess just looking at the performance may be the best answer to my questions.
Forum Rules
Old 10-09-07, 12:24 PM   #281
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
ISLAND1000 wrote: View Post
All the drivers came with rubber gaskets but the gaskets for the PRs were somewhat worse than the LMS-5400 gasket so I decided to use proper weather stripping with the PRs. I didn't have any problems with "mechanical hookup" or leaks.
The supplied bolts are sufficient.
Forum Rules
Old 10-09-07, 03:38 PM   #282
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
http://www.hometheatershack.com/foru...ll-2007-a.html
If someone hasn't noticed, first results (CEA-2010 standard) have been posted in that thread.
Forum Rules
Old 10-09-07, 10:27 PM   #283
Alias: Joe
Loc: Johnstown, PA
User: #6535
  jpmst3 is offline
Illka, can you please update the index to include all the latest tests?
Thanks!
Forum Rules
Old 10-09-07, 11:42 PM   #284
Alias: Jai
User: #7066
In terms of sheer output, your results co-relate pretty well to what I expected and experienced. .
Awesome job Ilkka. Kudos!
Forum Rules
Old 10-10-07, 12:01 AM   #285
Alias: Joe
Loc: Johnstown, PA
User: #6535
  jpmst3 is offline
Hmmmm, what is up your sleave Jai?
Forum Rules
Old 10-10-07, 03:59 AM   #286
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
jpmst3 wrote: View Post
Thanks!
What do you mean? All the latest info is here.
I can't update the index until I have processed the full results.
Forum Rules
Old 10-10-07, 08:48 AM   #287
Alias: Joe
Loc: Johnstown, PA
User: #6535
  jpmst3 is offline
Thanks for all the work you do.
I see, I didn't realize there was even more to do. I did see the results for the latest round and that is one amazing compilation of data.
I was just trying to make it all easier to find for others by having it all in one place. But, I didn't realize you were still working on it. Sorry for my ignorance to the testing process. I only stubled upon it the last couple of days. It seems the Shack is the better forum to be on.
Forum Rules
Old 10-10-07, 08:54 AM   #288
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
There is definitely A LOT more to do.
Each subwoofer will have its own thread similar to this for example.
Forum Rules
Old 10-10-07, 12:57 PM   #289
Alias: Joe
Loc: Johnstown, PA
User: #6535
  jpmst3 is offline
Excellent! I am looking forward to seeing All the data!
I can't thank you enough for taking the time and effort to do these tests.
The results are like the Holy Grail of woofage!
You are "the man!"
Forum Rules
Old 10-10-07, 01:00 PM   #290
Alias: Joe
Loc: Johnstown, PA
User: #6535
  jpmst3 is offline
jmcomp124 wrote: View Post
Just a psycho-acoustic related question about long/short term memory on subwoofer performance. Don't read into it too mcuh.
Ya, actually I do remember that thread over at AVS involving a certain rankings based person.
Forum Rules
Old 10-10-07, 02:16 PM   #291
Alias: Noah
Loc: Mountain View
User: #9449
Since: Jun 2007
  noah katz is offline
"If you heard the f113 one evening and the LMS, the next, can you tell the difference? If you heard a month apart? What if you heard them 2 months apart? How about 4 months apart?"
It would depend in large part on the listening level of course.
Forum Rules
Old 10-15-07, 11:10 AM   #292
Alias: cixelsid
User: #7293
Since: Mar 2007
  cixelsid is offline
DS-21 wrote: View Post
Interesting. I must admit some degree of..."disappointment" isn't quite the right word, but "underwhelmedness" isn't quite a word...with my Avalanche 18. (Condition shouldn't be an issue, as it was reconed by Fi before I ever saw it.) It's a great sub, but I was expecting a little more.
The original larger AA drivers had performance issues. Numerous people tested them to only find the T/S parameters didn't meet those published. Online conversations between DanW and Chad indicated the AA drivers had a rather 'generic' (read sub-optimal) implementation of the XBL^2 technology..
This information make one curious as to why anyone would favor the AA drivers over the newer offerings from other companies.
Forum Rules
Old 10-15-07, 05:06 PM   #293
Alias: Noah
Loc: Mountain View
User: #9449
Since: Jun 2007
DS-21,
I'm curious what exactly you found wanting in the Av18.
Are it and the JBL EQ'ed for similar freq response? Even then the room the JBL is in (smaller I presume for a 2nd system) could be giving it an advantage.
Forum Rules
Old 10-15-07, 09:21 PM   #294
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is offline
Can you reference this, cause I recall people saying such things but basing it off of "thumping the cone with their finger" and "it sure didn't sound like 16hz Fs" It would seem to meet its parameters related to shaping a FR based on my own FR measurements - as for travel limits, I don't know.
I've seen these conversations and I came across with the impression that Dan didn't like the idea of a competitor who was using his technology to create a less exensive product with more displacement getting more favorable reviews from end users, so he started talking about how all XBL^2 implementations aren't equal. The notion from enthusiasts at the time was essentially why should they spend $600 on a 15" Tumult when they can get an 18" Avalanche for $400 which sounds better anyway. In the small and fickle DIY subwoofer driver market, you can't let a notion like that spread too quickly. Problem is (from my point of view at least), he didn't provide any measurements or specs related to either the Avalanches or Tumults.
It's kind of the same thing with the LMS drivers. Dan essentially talked them down quite a bit in his comparison of XBL^2 to LMS, stating several reasons for XBL^2 being superior, yet when Ilkka put the rubber to the road, the LMS performs significantly better.
Forum Rules
Old 10-16-07, 01:06 AM   #295
Alias: Kyle Keating
User: #12285
Since: Oct 2007
  kyle_k is offline
Business is business Steve.
Forum Rules
Old 10-20-07, 03:33 PM   #296
Alias: Larry
User: #12618
Since: Oct 2007
  Larry McConville is offline
I realize I'm late to the LMS5400 party; any thoughts about organizing a group buy and having TC build some units? I was sitting on the fence because rumor had it that Deon was trying to organize something; next thing I know he had already parted company with TC. I suppose I'm just thinking out loud...
Forum Rules
Old 10-21-07, 09:04 PM   #297
Alias: steve
Loc: Sherwood Or
User: #1699
  steve nn is offline
I wonder if that could be a possibility? No more MDF though
Forum Rules
Old 10-21-07, 11:45 PM   #298
Alias: Kyle Keating
User: #12285
Since: Oct 2007
  kyle_k is offline
All our efforts are on Audiopulse now. the 5400's are replaced with the Ultra's with some improvements to durability and power handling.
Forum Rules
Old 10-22-07, 08:24 AM   #299
Alias: Shervin
ssabripo's Avatar
Loc: Florida
User: #3688
Since: Nov 2006
  ssabripo is offline
too bad Kyle.....because at those prices, the sales of the "ultra" will be few and far in between I'm afraid.
I remember when Deon (with my help) was trying to organize a group buy over at avs, but Bott shut my thread down....anyways, there was plenty of interest in getting a group buy of the LMS5400 18" at around $750 if we could get at least 20 buys.
If Thilo decided to throw something like that together, and sell some Ultras for say $800 if we could sign up 20 people, I think it will be a good success.
just food for thought.
Forum Rules
Old 10-22-07, 08:47 AM   #300
Alias: Larry
User: #12618
Since: Oct 2007
If we could come in around the $750 mark I'll sign up for 2 - 4 units!
Larry
ssabripo wrote: View Post
Forum Rules
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived »
