Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived
LMS-5400 buy-in
Discuss LMS-5400 buy-in in the Manufactured Speakers and Subwoofers forum; LMS-5400 buy-in jmcomp124 wrote: Hi Buddy, I just got your email and sorry I have not been that active at avs or ...
Alphabetical Search
All # A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
 Closed Thread     Post New Thread
Views: 24603 - Replies: 311
Old 09-07-07, 11:01 AM   #101
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Re: LMS-5400 / RL-p18" buy-in
jmcomp124 wrote: View Post
Hi Buddy,
I just got your email and sorry I have not been that active at avs or here since I have been so busy with work. So about the PRs, you do need more washers and TC did not send me enough and I had to request more. I stopped at our local Home Depot Store (a common store in the US) and they did not have washers that size.
I requested more from Kyle and he promptly shipped me more. I think you will need a lot more than 10, so bug TC to send you more. With the way things are going with them, I don't know how lucky you will be, but make a big noise as those folks should know better. What the while shipping overseas why not send out more washers. I hate it, when such things happen. In the meantime, can you come up with something creative about adding more weights? It doesn't have to be washers you see !
Hi Jai,
Well here's what Kyle wrote me: "You can buy more washers at a hardware store, they should not be anymore than a buck each." I really thought that they would include washers up to 2500g as the webpage says/said. I'm not sure if I can find such washers locally.
How is the CE4000 performing?
I haven't done any thorough testing yet because that fan is definitely too loud. I need to buy a quieter one asap. I tried it briefly without the fan, and the heat sink came pretty hot already during low level listening. That's kinda strange when thinking about its efficiency? My other Class B amp (TA2400) can easily be used without a fan (not max power though).
Forum Rules
Old 09-07-07, 11:02 AM   #102
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
I used to lift heavy weights and turning that thing off the cone requires some serious torque.
How did you do it? It took me a few tries before I got the sucker off. I had to replace a cone and VC that I misaliged becuase of not using a HP filter.
I just grabbed the frame and gave it a quick twist.
Forum Rules
Old 09-07-07, 11:03 AM   #103
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
noah katz wrote: View Post
Ilkka,
"Regarding those passive radiators. Mine have only single 10" spider; someone over at AVS posted pics of his PRs, and they have dual spiders?"
IMO that's a good thing.
A little bit of cone rocking (which dual spiders are meant to prevent) won't hurt anything and the lower the suspension stiffness/Fs of a PR, the better.
Here's Kyle's reply: "Don't worry about the spiders. We added a second one to the last run because we're migrating a lot of stuff to car audio where they really abuse everything. If you're using 2 PR's per active then it should never be a problem."
Forum Rules
Old 09-07-07, 12:09 PM   #104
Alias: Jai
Loc: Portland, OR, USA
User: #7066
  jmcomp124 is offline
Ilkka wrote: View Post
Hi Jai,
You may want to try in the plumbing section of your local hardware store as there is a better chance of finding such large washers or nuts.
Yes, the fan is obnoxiously loud and that was the first mod I did. As I mentioned before, the SilenX fans have worked out pretty good for me. The amps did not overheat during movies but when left on overnight, at times (twice), in the morning I saw one of the amps go into protection mode (flashing red lights). It was also in the warm corner of the room.
These amps will bring out the full potential of your LMS. I would go very easy on the drivers without a HP filter. You know all the issue I had without the filter. The last thing you want is your woofer bottoming out on you. Since your tests are very controlled, I think you will find it's limitations very quickly and safely.
Forum Rules
Old 09-07-07, 12:15 PM   #105
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Comparison to 15" TC-2000, which can't be called a small woofer either. Somehow it just becomes so small next to the LMS.
The LMS next to a standard Finnish 0.5 liter beer can.
Forum Rules
Old 09-07-07, 03:38 PM   #106
Alias: Noah
Loc: Mountain View
User: #9449
Since: Jun 2007
  noah katz is offline
"If you're using 2 PR's per active then it should never be a problem."
I stick with my contention that it doesn't matter for a PR no matter how hard you drive it.
Forum Rules
Old 09-07-07, 06:09 PM   #107
Alias: Scott
Loc: Clovis, CA
User: #7981
Since: Apr 2007
  Scott S is offline
Im not sure if its been mentioned lately or not....
Are you still planning on picking up a Sound Splinter RL-p18 to test, Ilkka?
Forum Rules
Old 09-08-07, 01:46 PM   #108
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Scott S wrote: View Post
The RL-p18" test has been postponed. At the moment I simply do not have enough time. Hopefully next spring...
Forum Rules
Old 09-08-07, 08:07 PM   #109
Adam321
Inactive
Alias:
User: #
Posts: n/a
Too bad you didn't test the RL-p18 first. I would be more interested in that. THe LMS-5400 is unobtainable at the moment and who knows the future of TCsounds? Why drool over something that you can even get.
Forum Rules
Old 09-08-07, 08:10 PM   #110
Iggster1986
Inactive
Alias:
User: #
Posts: n/a
Adam321 wrote: View Post
http://www.audiopulse.com/products/s...vers/lms-ultra
patience.....
Forum Rules
Old 09-08-07, 08:12 PM   #111
Iggster1986
Inactive
Alias:
User: #
Posts: n/a
I cant wait for the test's I am planning on buying a pair of the new ultras once the dealers have them in stock depending on test results here.
Forum Rules
Old 09-08-07, 08:29 PM   #112
Alias: anidabi
Loc: Finland
User: #9482
Since: Jun 2007
  anidabi is offline
Iggster1986 wrote: View Post
Hmmm... okay, so audio pulse has now almost the whole TC-Sounds lineup. I wonder how expensive the drivers will be?
Forum Rules
Old 09-08-07, 09:48 PM   #113
Iggster1986
Inactive
Alias:
User: #
Posts: n/a
anidabi wrote: View Post
Depending how good you know your dealer or how good they are with prices, I would say barely more to double the price depending on those things.
Forum Rules
Old 09-17-07, 12:34 AM   #114
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is online now
Ilkka, I believe you took a close mic, in-room THD measurement of the TC2k in free air a while back and the room didn't affect it too much. Any chance you could do the same with this driver to get an idea of what it can offer?
Forum Rules
Old 09-17-07, 06:08 PM   #115
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
SteveCallas wrote: View Post
Yes, I will take these in a few days. I will also add the SDX15 in the mix.
Forum Rules
Old 09-18-07, 04:27 PM   #116
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Distortion/frequency response comparison
OK, here we go.
I have took some near field (around 8" distance), in-room measurements in "free air" (naturally there are some room reflections but there was no enclosure) for a few drivers I have currently in my possession. I used the same 30 second linear sine sweep as I use in my GP subwoofer tests. I tried to to match the SPL around 50-60 Hz. I started at 90 dB and went up using 5 dB steps. So THD graphs are showing curves at 90 dB, 95 dB, 100 dB, and 105 dB levels (remember 8" distance). No auto-levelling etc. was used, so the SPL is only absolute around 50-60 Hz. Everywhere else frequency response dictates the absolute SPL. Also these results are no way comparable to any GP measurement.
Don't take these measurements as the absolute truth because such in-room tests have always much greater error margin and they aren't as accurate as GP measurements.
The drivers tested were:
CSS SDX15
TC Sounds LMS-5400 18"
TC Sounds TC-2000 15" (alu cone, half-roll surround)
TC Sounds TC-2000 15" (ti cone, tall profile surround)
Let's start with the frequency responses. This graph doesn't show which driver is the most efficient because SPL's were matched. Though I can say that they all are pretty much identical when it comes to average efficiency/sensitivity. No more than ~1 dB differences.
The tall profile surround/ti cone TC2k seems to roll-off slightly faster than the regular half-roll surround/alu cone. Both of them have the greatest upper-end roll-off. The SDX15's upper-end is flatter and the frequency response extends lower but the final roll-off is steeper. The LMS-5400 has the most shallow roll-off and also the greatest upper-end output. The graph shows the frequency responses only up to 100 Hz but also above the trend is the same.
And now some distortion results. Let's start with the SDX15. It has the famous XBL^2 motor which should keep the distortion low. Indeed distortion stays quite low during "90 dB" and "95 dB" sweeps but grows pretty quickly at higher levels, especially below 20 Hz. The reason for this might be the single 8.5" spider (TC Sounds drivers have dual 10" spiders) which causes suspension-related distortion at low frequencies. The amount of distortion stays quite linear above ~20 Hz.
Then we have the TC-2000 (alu cone/half-roll surround). Distortion stays slightly lower than with the SDX15 everywhere else than in 20-60 Hz range where it forms a slight hump.
The TC-2000 with the titanium cone and tall profile surround shows pretty similar results. The hump in 20-60 Hz range is around 1% lower but nothing drastic. Could be just a slight difference in T/S data.
And then the big boy, the LMS-5400 18". I don't think much has to be said, other than the low frequency distortion during two lowest sweeps was so low that the background noise started to affect too much, so I didn't plot them. A great performance especially when noticing that it had the most output during those sweeps above ~55 Hz. In laboratory conditions (lower background noise) it could probably stay below 1% THD at all frequencies even during the "105 dB" sweep. A friendly suggestion to all LMS-5400 owners: Don't sell them.
Forum Rules
Old 09-18-07, 04:39 PM   #117
Iggster1986
Inactive
Alias:
User: #
Posts: n/a
just wow on the lms....
Forum Rules
Old 09-18-07, 05:26 PM   #118
Alias: Geoff
Geoff St. Germain's Avatar
Loc: Winnipeg, Canada
User: #4919
Since: Dec 2006
  Geoff St. Germain is offline
Wow, the LMS is ridiculous.
Forum Rules
Old 09-18-07, 06:42 PM   #119
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Some further distortion analysis.
Here are the THD spectrum's of the SDX15, TC-2000 and LMS-5400 at 60 Hz. I have marked the first five (H2 - H6) harmonics. Other spikes are just 50 Hz hum or other background noise.
Here's a comparison between the SDX15 and LMS-5400. You can see that the LMS-5400 doesn't have much even-order harmonics. H3 (=180 Hz) is the dominant one.
Here's a comparison between the SDX15 and TC-2000. They are much closer to each other than the LMS-5400 is to either one of them.
Forum Rules
Old 09-18-07, 07:12 PM   #120
Alias: PHIL
ISLAND1000's Avatar
Loc: SHERMAN, TX
User: #8655
Since: May 2007
  ISLAND1000 is offline
I have my LMS mounted in a 6.8 cubic foot sealed box driven by a Crown XTi 4000. The amazing test results you're getting via the open air near field tests ARE easily discernable when the speaker is placed in an enclosure and driven by a suitable amp.
The response is amazingly flat or at least my listening room and the Crown amp DSP allow me to adjust it so it is . . . . at least to MY ear. The distortion is unoticeable even when the signal strength is very high and the sounds are very low. I played a 10-19 Hz sweep from the Sheffield "My Disc" 2000, track 59. It was absolutely jaw dropping to watch the titanium cone move close to it's full 38 mm Xmin and still produce controlled sonic havoc within my listening environment. I wasn't sure at first, when I cranked up the volume, whether I should stand so close to something that was that loud and violent. It shook my concrete floor and had my pants flapping like the Finnish Flag! It's truly an amazing piece of equipment.
I've been listening to (and watching) the "Discovery Channel" and have the the amp EQed through the DSP of the Crown amp. There is much subsonic music AND sounds in the background of most programing on the Discovery Channel. The program I watched first and noticed the subsonic revelations was " The Dirtiest Jobs " with Mike Rowe. It's a "must hear" and humorous too.
This LMS monster, IS a sonic marvel! Wait till you get yours in a box Ilkka. Like you suggested to those of us who own them, "Don't sell them"!
Forum Rules
Old 09-18-07, 10:10 PM   #121
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
  WillyD is offline
Wow, wow, wow....wow. I mean...I had my suspicions concerning the LMS, but I honestly didn't think it'd test that well. And just thing, just months ago an 18" was "only" $875 shipped.
Forum Rules
Old 09-18-07, 10:39 PM   #122
Alias: Robert
Loc: Ny, NY
User: #17
  Exocer is offline
Breathtaking performance for the LMS-5400, I really wished I played it smart and saved for one of them the first time around and be done with it
Too bad they're not available anymore
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Forum Rules
Old 09-18-07, 11:05 PM   #123
Alias: Jai
User: #7066
I am not surprised at all.
Awesome work Ilkka. Can't wait to see the outdoor measurements. I guess the skeptics may start believing my words now about how good this woofer sounds. And for those who waited and doubted too much, too sad and for those who bought on time .
Forum Rules
Old 09-19-07, 12:30 AM   #124
Alias: Steve
User: #263
Looking back at how TC Sounds released and advertised this woofer, I think they really missed the target. Had they merely done a FR and THD test akin to yours Ilkka, just about every DIY'er willing to spend up to $1000 would have bought one....or two. That thing is amazing. I'm just baffled now though about how easy it would have been for them to sell a ton more. Yeah yeah, people will say that DIY'ers are a very small percentage of their business, but with this driver being so clearly superior to anything else out there, again, I can see EVERY enthusiast buying one. They'd have sold at least 75x what they did going about things they way they have
Forum Rules
Old 09-19-07, 12:39 AM   #125
Alias: Will
Loc: Matthews, NC
User: #2437
Since: Sep 2006
  WillyD is offline
I agree that a FR/THD like Ilkka has done here would've done a whole lot as far as "selling" the 5400.
But I think you're forgetting that TC Sounds had no real problem selling them. They actually sold out of them long before they sold out of their much cheaper offerings. The problem they had was building enough of them.
Forum Rules
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived »
