| Subwoofer Tests - Archived Chorus Vertigo XLS 07Discuss Chorus Vertigo XLS 07 in the Manufactured Speakers and Subwoofers forum; Chorus Vertigo XLS 07 Manufacturer: Chorus/OR
Model: Vertigo XLS 07
Provided by: Kymen Laatulaite
Manufacturer link: Chorus
Price: 649 EUR
Manufacturer specs:
• Drive ... |
| Alphabetical Search | |||||||||||||||||||||||||||
| All | # | A | B | C | D | E | F | G | H | I | J | K | L | M | N | O | P | Q | R | S | T | U | V | W | X | Y | Z |
Views: 2046 - Replies: 5
| Chorus Vertigo XLS 07 Manufacturer: Chorus/OR Model: Vertigo XLS 07 Provided by: Kymen Laatulaite Manufacturer link: Chorus Price: 649 EUR Manufacturer specs: • Drive unit: 1 x 269 mm • Frequency response: 20...50-120 Hz • Amplifier: UcD 200 W • Phase: Variable and 0/180 switch • Level: Variable • Low pass filter: Variable 30…120 Hz, 18 dB/oct. • Subsonic-filter: 12Hz / -3dB, 24dB/oct. • Bass EQ: 50...120Hz, 0...+6dB adjustable • Measurements: (H,W,D) 441 mm x 441 mm x 441 mm • Weight: 29.7 kg • Volume: 47 l • Finish: Trend (EAN: 6416716103838 ), Elegant (EAN: 6416716103746 ), Black Diamond (EAN: 6416716103739 ), Avantgarde (EAN: 6416716103784 ) Configuration as tested: Phase: 0 degrees Crossover: Bypassed EQ: Off Orientation: Standard down-firing, woofer and ports facing the ground ![]() ![]() | ||||
