| Subwoofer Tests - Archived SVS PB12-NSD - #1Discuss SVS PB12-NSD - #1 in the Manufactured Speakers and Subwoofers forum; SVS PB12-NSD - #1 Manufacturer: SV Sound
Model: PB12-NSD
Provided by: KmoK78
Manufacturer link: SV Sound , L-Sound
Price: 888 EUR
Manufacturer specs:
| Alphabetical Search | |||||||||||||||||||||||||||
| All | # | A | B | C | D | E | F | G | H | I | J | K | L | M | N | O | P | Q | R | S | T | U | V | W | X | Y | Z |
Views: 5576 - Replies: 5
| SVS PB12-NSD - #1 Manufacturer: SV Sound Model: PB12-NSD Provided by: KmoK78 Manufacturer link: SV Sound, L-Sound Price: 888 EUR Manufacturer specs: • SVS designed/built long-throw 12" driver • Full-featured 325 watt BASH digital amp • Computer Assisted Design (CAD) enclosure • Dual CNC'd internal braces • Three color choices with removable grill • Front-firing woofer/port for easy installs • Built-in, flush-mount amp configuration • Compliant floor mounts (six) • Patented 4" high-flow flared porting (in and out). • Extra heavy-duty removable 8 foot power cord • "Seamless" cabinet design in three colors • +/-3dB 18Hz-200 Hz anechoic extension • Size: 18" wide x 21" high x 25" deep, 45 cm wide x 52 cm high x 62 cm deep • Weight: 74 pounds, 34 kg Configuration as tested: Phase: 0 degrees Crossover: Bypassed Orientation: Woofer and port facing the mic ![]() ![]() | ||||
