Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived
SVS 20-39PC+ 16 Hz tune (dB12.2)
Discuss SVS 20-39PC+ 16 Hz tune (dB12.2) in the Manufactured Speakers and Subwoofers forum; SVS 20-39PC+ 16 Hz tune (dB12.2) Manufacturer: SV Sound Model: 20-39PC+ Provided by: Ate Manufacturer link: SV Sound Price: $899 Manufacturer specs: • 525 watt, built-in ...
Alphabetical Search
All # A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
 Closed Thread     Post New Thread
Views: 1287 - Replies: 5
Old 08-19-07, 09:19 AM   #1
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Model: 20-39PC+
Provided by: Ate
Price: $899
Manufacturer specs:
• 525 watt, built-in amplifier
• 20 Hz extension (variable to 16 or 12Hz)
• +/- 3 dB 20 Hz-100 Hz (20Hz mode)
• 39" tall, 16" in diameter
• Proprietary TC-Sound 12" high output woofer
• Computer Assisted Design (CAD) cylindrical enclosure
• Flush mounted, 525 watt BASH amp (220V. avail)
• Exclusive SVS down-firing woofer with integrated base
• Compliant disk floor mounts, low center of gravity
• "Tri-Power" 3" high-flow ports with custom port block
• Resonance free, protective port grill
• CNC'd, black polymer laminated, 1.5" birch end-caps
• Architectural-grade black fabric exterior
Configuration as tested:
Phase: 0 degrees
Tuning frequency: 16 Hz (one port plugs)
Subsonic filter: 16 Hz
Top grill removed
Orientation: Standard down-firing
This unit has a dB12.2 woofer
Forum Rules
Old 08-19-07, 09:20 AM   #2
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Re: SVS 20-39PC+ 16 Hz tune (dB12.2)
+/- 3 dB points: 14.5 Hz - 100 Hz
Forum Rules
Old 08-19-07, 09:20 AM   #3
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Forum Rules
Old 08-19-07, 09:20 AM   #4
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Forum Rules
Old 08-19-07, 09:20 AM   #5
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Forum Rules
Old 08-19-07, 09:20 AM   #6
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
The frequency response is a little bit better than at the 20 Hz tune. Naturally the same slope towards the high frequencies remains, but since the response extends lower, it doesn’t look quite that bad. The -6 dB point goes as low as 14.5 Hz which easily transfers close to 10 Hz extension in a typical room. The maximum output in mid bass range is slightly weaker than at 20 Hz tune, but the very low frequency output naturally gets a nice boost. The power compression grows rather large around the tuning frequency which suggests that the subwoofer is heavily under ported.
The THD profile is similar to the 20 Hz tune, though naturally the 16 Hz tune performs a little bit better at the very low frequencies. The group delay stays under the 1 cycle limit all the way down to 15 Hz. The spectral decay graph shows around 200 of ringing around the tuning frequency; slightly more that at 20 Hz tune.
Changing the tuning frequency by plugging one or more of the ports has some advantages, mainly the added extension, but also some drawbacks. The reduced port area is one major drawback which causes even more port chuffing and port compression at higher levels than with all available ports open. Therefore I would suggest choosing the subwoofer which has the native tune that you’re going to use, rather than buying a higher tuned subwoofer and then plugging its port(s).
Due its flatter frequency response, the 16 Hz tune is more suited to music use than the 20 Hz version. Movie fans will have more extension but also reduced output at higher.
+ High output in 15-40 Hz range
+ Low distortion
+ Extremely good extension
- Slightly uneven frequency response
- Medium upper bass output
- High power compression around the tuning frequency
- Slow decay rate at low frequencies
Forum Rules
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived »
