Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived
SVS PB12-Ultra 12 Hz tune
Discuss SVS PB12-Ultra 12 Hz tune in the Manufactured Speakers and Subwoofers forum; SVS PB12-Ultra 12 Hz tune Manufacturer: SV Sound Model: PB12-Ultra Provided by: Ilkka Manufacturer link: SV Sound Price: $1199-$1399 (depending of finish) Configuration as tested: ...
Alphabetical Search
All # A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
 Closed Thread     Post New Thread
Views: 2707 - Replies: 3
Old 08-19-07, 09:26 AM   #1
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Model: PB12-Ultra
Provided by: Ilkka
Phase: 0 degrees
Tuning frequency: 12 Hz (two port plugs)
Subsonic filter: 12 Hz
Orientation: Standard down-firing, ports facing right
NOTE: Only partial tests were taken due to time constraints
Forum Rules
Old 08-19-07, 09:27 AM   #2
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Re: SVS PB12-Ultra 12 Hz tune
+/- 3 dB points: 10 Hz - 150 Hz
Forum Rules
Old 08-19-07, 09:27 AM   #3
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Forum Rules
Old 08-19-07, 09:27 AM   #4
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Due the lack of time, I performed only a limited battery of tests for the 12 Hz tuned version. I also feel that the subwoofer is seriously under ported in this configuration and isn’t the best use of the subwoofer. The frequency response extends down to 10 Hz (-6 dB), but there is a prominent hump in 25-50 Hz range. The group delay stays well below the 1 cycle limit all the way down to 15 Hz. As expected, the subwoofer rings the longest around its tuning frequency at ~11 Hz.
12 Hz tuned Ultra is the best choice to those in small rooms and lots of low frequency room gain. Though it should be noticed that the output capabilities at higher frequencies are reduced quite heavily. Therefore this lowest tune is geared towards music use.
+ Relatively flat frequency response
+ Extremely good extension
+ Relatively low group delay
- Slow decay rate at very low frequencies
- Reduced output above 20 Hz
Forum Rules
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived »
