Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived
Subwoofer driver buy-in poll
Discuss Subwoofer driver buy-in poll in the Manufactured Speakers and Subwoofers forum; Subwoofer driver buy-in poll Attached are the T/S parameters and Klippel data from the review. I'm not an expert in copyright law so if ...
Alphabetical Search
All # A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
View Poll Results: Which drivers would you like to see being tested AND could chip in to make it happen?
Ascendant Audio Avalanche 18 8 15.09%
Sound Splinter RL-p15/18 31 58.49%
Fi Q15/18 15 28.30%
Mach5Audio IXL-18.4 9 16.98%
Dayton RSS390HF/HO 12 22.64%
Something else? (post it) 11 20.75%
Multiple Choice Poll. Voters: 53. You may not vote on this poll
 Closed Thread     Post New Thread
Views: 7228 - Replies: 95
Old 02-06-08, 12:52 PM   #76
Alias: Chris
User: #9329
Since: Jun 2007
  Chris Brunhaver is offline
Re: Subwoofer driver buy-in poll
Attached are the T/S parameters and Klippel data from the review. I'm not an expert in copyright law so if the mods need to take it down, I respect that.
The editorialize a bit, obviously with an 18.25 mm "underhang" and a long coil the driver has very linear BL and due to using a 6" diameter 2-layer coil and copper sleeve on the has very high power handling and good low Le, good Xmax etc.
I know that drivers like this and the LMS TC sounds stuff capture the imagination of DIYers but I think that people are missing the point a bit. With the research that has been done by Harman and others showing how multiple LF sources having a very positive impact in smoothing rooms modal responses, the question isn't who can build the best $1k woofer, unless you have a lot of money to build 4 of them. Instead, four $250 woofers would be a better bet for that $1k budget. As engineering is really the art of doing the most with the least (and furthermore fits within the demands of the application from all other factors therein) these brute force approaches are not that interesting to me personally.
Forum Rules
Old 02-06-08, 01:48 PM   #77
Shack Moderator
Alias: Josh
Ricci's Avatar
Loc: Louisville, KY
User: #9132
Since: May 2007
  Ricci is offline
The data looks pretty good to me.
Forum Rules
Old 02-06-08, 01:51 PM   #78
Alias: Andrew
avaserfi's Avatar
Loc: College Station, TX
User: #9992
Since: Jul 2007
  avaserfi is offline
Chris Brunhaver wrote: View Post
I completely agree with you on this one. Also, the Infinity Kappa Perfect/VQ series is a perfect high quality budget option for such a situation. Eventually I will have four of them in use for movies and two in stereo use for 2-channel listening.
The thing is raw power just seems so much cooler than a bunch of "little" subs.
Andrew
Forum Rules
Old 02-06-08, 02:46 PM   #79
Alias: vinculum
Loc: York, Pa.
User: #6599
  vinculum is offline
We're just evaluating the driver here, not a bass system. If you have $1000 to spend and your goal is value based, then Acoupower isn't the best bang for the buck. Four lower cost drivers would then make the most sense. I have 2 of these Acoupower 18" drivers which will be non co-located. I'm not really on a budget so, I'd have no problem getting 2 more if needed.
Chris, thanks for sharing that data. I was also expecting an article to go along with it. If there is one, could you include that?
Thanks!
Dr V
Forum Rules
Old 02-06-08, 10:55 PM   #80
Alias: PHIL
ISLAND1000's Avatar
Loc: SHERMAN, TX
User: #8655
Since: May 2007
  ISLAND1000 is offline
There are many ways to energize a listening area with low frequency power. I'm among those who like to see it done with just a couple drivers in smaller boxes. To do that requires special build qualities and design techniques using special materials and a person with a unique personal drive to keep advancing the technology. Acoupower is one of those special drivers.
Sub drivers more than mid range or tweeters peak my interest, kinda like other things that fit formulas IE: 12 oz. Bud Light, Dbl quarter pounder w/cheese, 36-24-36, Corvette Z06, etc.
Forum Rules
Old 02-07-08, 03:50 PM   #81
Alias: Noah
Loc: Mountain View
User: #9449
Since: Jun 2007
  noah katz is offline
"With the research that has been done by Harman and others showing how multiple LF sources having a very positive impact in smoothing rooms modal responses, the question isn't who can build the best $1k woofer, unless you have a lot of money to build 4 of them."
I agree, but note that two subs gave results nearly as good as four and is much more practical for most people.
Forum Rules
Old 02-08-08, 12:16 AM   #82
Alias: Steve
SteveCallas's Avatar
User: #263
  SteveCallas is offline
Absolutely. I don't get the mega bucks driver that requires a mega bucks amplifier that requires a dedicated 20 amp line approach unless one is absolutely strapped for space.
Forum Rules
Old 02-08-08, 08:03 AM   #83
Alias: Larry
User: #12618
Since: Oct 2007
  Larry McConville is offline
Valid points; however, we must realize this is a hobby and folks have different tastes. I believe it keeps the hobby enjoyable and engaging.
SteveCallas wrote: View Post
Forum Rules
Old 02-08-08, 01:33 PM   #84
Alias: vinculum
Loc: York, Pa.
User: #6599
  vinculum is offline
Compromise has many avenues. Some may be strapped for space, others may be strapped for cash. DIYers strive to do the best with what is available to them.
Forum Rules
Old 03-05-08, 06:10 PM   #85
Alias: anidabi
Loc: Finland
User: #9482
Since: Jun 2007
  anidabi is offline
Ilkka wrote: View Post
And if the Maelstrom 18 (XJ-18) will be ready before my tests begin, it will also going to be tested.
I sure hope to see this thing at your subwoofer shootout. The final engineering sample parameters have been published and the production should start during april. So I guess it will not be in the spring shootout?
Here you can find the parameters.
Forum Rules
Old 03-13-08, 05:09 PM   #86
New Member
Alias: Maq
Loc: Canada
User: #18048
Since: Mar 2008
  marstedt is offline
I would like to see the Mach5Audio IXL-18.4 as well as the MJ-18 tested since these are both easily accessible in Canada.
Forum Rules
Old 03-15-08, 02:56 PM   #87
Alias: Ahmed
Blaser's Avatar
Loc: Cairo-Egypt
User: #2269
Since: Aug 2006
  Blaser is offline
A bit late to this thread but I will have my word:
I wonder why we are making Ilkka's life difficult with so many questions/investigations. What is so hard not to understand?
Illka is one of the biggest (if not the biggest) subwoofer tester in the world, and he is young (BTW). Nevertheless he has tested so many subs and we all benefit from the results for free.
Now either you are willing to help, or you aren't. If you are, consider this money an encouragement to Ilkka for the unpaid time and efforts that he is doing exclusively for the shacksters, leave aside all the investment that has done in these tests as far as drivers/enclosures/shipping/transportation....
I don't give a care to my 40 or 50 bucks that I donate after the tests for a specific driver or whatever. Just consider it as an encouragement to Ilkka's tests. But the kinda "what will our money become when it is transformed into a sub" is not very ethical IMO.
ASME AI
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Forum Rules
Old 04-02-08, 09:45 PM   #88
Alias: vinculum
Loc: York, Pa.
User: #6599
  vinculum is offline
Ilkka,
How are we doing on acquiring an Acoupower driver for testing?
I just noticed there is a 15% off sale for Acoupower drivers for the month of April. A great time to buy if we have enough interest! I'll chip in a little more if it will make a difference...
Dr V
Forum Rules
Old 05-18-08, 12:53 PM   #89
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
vinculum wrote: View Post
Ilkka,
Dr V
I though we were progressing quite nicely but now Carlos haven't replied to my e-mails for a quite a long time. I don't know what's happening.
Forum Rules
Old 05-18-08, 05:22 PM   #90
Alias: Noah
Loc: Mountain View
User: #9449
Since: Jun 2007
I wish he would stop disappearing like that, it reduces one's confidence in support for the product being available if needed.
Forum Rules
Old 05-18-08, 08:37 PM   #91
Alias: Funky Waves
User: #9943
Since: Jul 2007
  funky_waves is offline
Last time I talked with carlos, last week I believe, he is very busy. I would call him. It sounded like he would like to get one to Illka.
Nathan Funk
Funky Waves Audio
Forum Rules
Old 05-19-08, 01:14 AM   #92
Alias: vinculum
Loc: York, Pa.
User: #6599
  vinculum is offline
I talked to him via email last night. I nudged him a little, hopefully he will get back to you. He is now an authorized Crown dealer!
I'm now a Crown man myself, having picked up a pair of CE4000's.
Dr V
Forum Rules
Old 05-24-08, 11:19 AM   #93
Alias: Funky Waves
User: #9943
Since: Jul 2007
I think we should all call and nudge him, I realy want to see tests on this sub now, that I have one, listening to it right now. I was sceptical, I knew it would be great but I wasnt sure if it would measure up, haveing gotten used to the LMS5400
Nathan Funk
Funky Waves Audio
Forum Rules
Old 05-24-08, 02:10 PM   #94
Alias: Noah
Loc: Mountain View
User: #9449
Since: Jun 2007
"I was sceptical, I knew it would be great but I wasnt sure if it would measure up, haveing gotten used to the LMS5400"
And the verdict is....
Forum Rules
Old 05-24-08, 02:52 PM   #95
Alias: Funky Waves
User: #9943
Since: Jul 2007
To early for a verdict, but it definitly rivals the LMS. It seems to have better upper bass in initial impression. Very articulate and accurate bass. I will have to swap them back and forth a few times to see for sure what I prefere.
Nathan Funk
Funky Waves Audio
Forum Rules
Old 05-24-08, 07:12 PM   #96
Alias: Noah
Loc: Mountain View
User: #9449
Since: Jun 2007
"To early for a verdict, but it definitly rivals the LMS. "
Sounds promising, thanks.
Forum Rules
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived »
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
