Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived
DIY Chorus XP3 clone
Discuss DIY Chorus XP3 clone in the Manufactured Speakers and Subwoofers forum; DIY Chorus XP3 clone Manufacturer: DIY Provided by: Kinks-58 Manufacturer link: Suomen Hifitalo Oy (original model) Price: Not calculated (original model is 520 EUR ...
Alphabetical Search
All # A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
 Closed Thread     Post New Thread
Views: 3097 - Replies: 3
Old 07-16-06, 03:08 PM   #1
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Manufacturer: DIY
Price: Not calculated (original model is 520 EUR )
Manufacturer specs:
• Enclosure: Passive radiator, ~35 litres, 18 mm real birch + 12 mm plywood, heavily braced with 18 mm MDF and concrete/lead alloy
• Woofer: Peerless XLS 12”
PR: Peerless 830549 (618 g)
• Amplifier (external): Hypex HS-200 (125 W into 8 Ohm, 200 W into 4 Ohm)
• Crossover: 30-120Hz, 24 dB/oct.
• Phase: Variable 0-180 degrees
• Subsonic filter: Yes @ ~18 Hz (bypass available)
• Weight: 46 kg
Configuration as tested:
Phase: 0 degrees
Subsonic filter: On (FR graph was taken without a SS filter)
Orientation: Sideways
Forum Rules
Old 07-17-06, 11:01 AM   #2
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
+/- 3 dB points: 21 Hz - >200 Hz
Forum Rules
Old 07-17-06, 11:02 AM   #3
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Forum Rules
Old 07-17-06, 03:31 PM   #4
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
This subwoofer is built like a tank. I couldn't believe how heavy it was until I tried to pick it up. The shape of the frequency response is really good. Slowly sloping response matches well with room gain. Max output is rather good for such a small sub, though the 105 dB sweep produced a lot of distortion due amp clipping. With a more powerful amp the 105 dB sweep could have been much more cleaner and probably even compression-free. At lower output levels the THD stays really low at all frequencies. THD consists mainly from 2nd order component which makes it even less audible. Group delay rises pretty rapidly below 30 Hz, but it shouldn't be that audible. Spectral decay shows some ringing around 20 Hz, but it's still better than average. Spectral contamination tests shows better than average performance and I'm pretty sure the 100 dB level could have been possible with a more powerful amp. A really nice looking sub with a respectable performance. It also has an external amp which can be switched easily.
+ Good extension and very good shape of the frequency response
+ Low distortion up to 100 dB output level
+ Reasonably low group delay and short decay time
+ Really strong and rigid enclosure
- Weak amplifier
- Maximum SPL capability
- Slightly high group delay at the low end
Forum Rules
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived »
