Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived
Genelec 7070A
Discuss Genelec 7070A in the Manufactured Speakers and Subwoofers forum; Genelec 7070A Manufacturer: Genelec Model: 7070A Provided by: Genelec Manufacturer link: Genelec 7070A Active Subwoofer Price: $2850 Manufacturer specs: Short term RMS ...
Alphabetical Search
All # A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
 Closed Thread     Post New Thread
Views: 2473 - Replies: 3
Old 07-16-06, 03:43 PM   #1
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Genelec 7070A
Model: 7070A
Price: $2850
Manufacturer specs:
Short term RMS @ 1 m (halfspace) 112 dB SPL
Input channels 6
Sum out outputs 1
Driver 12"
Free field frequency response 19 - 85 (120) Hz +/- 3 dB
Bass level +12 to -6 dB (variable)
Bass roll-off 0 to -6 dB (2 dB/step)
Phase adjustment 0 to 270° (90°/step) @85 Hz
Amplifier power 250 W
Dimensions (H x W x D) 625 x 555 x 490 mm, 24 5/8 x 21 7/8 x 19 5/16”
Weight 50 kg (110 lb)
Configuration as tested:
Phase: 0 degrees
Bass roll-off: 0 dB
Orientation: Woofer facing the mic
Forum Rules
Old 07-17-06, 11:11 AM   #2
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
+/- 3 dB points: 16.5 Hz - 110 Hz
Forum Rules
Old 07-17-06, 11:12 AM   #3
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Forum Rules
Old 07-17-06, 03:25 PM   #4
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Similar to its smaller brothers, only now with a 12” driver and naturally larger enclosure, the 7070A provides a flat frequency response with a really good 16.5 Hz extension. This suits better for rooms not having much deep bass room gain. Otherwise the low end of the response tilts up and the sound becomes too bottom heavy. The low pass filter slope is very steep, but the lowest setting is only around 80 Hz, meaning a proper 2-channel use requires an external filter. The 105 dB sweep was affected by the built-in limiter which limits the amp output in order to protect the voice coil from over-heating. That causes the sudden drop in output. You won't see this kind of phenomenon with normal program material. THD stays really low above 50 Hz, but starts to climb up at lower frequencies during 100 dB and 105 dB sweeps. Composition of the THD is a typical for all the Genelec’s, 3rd harmonic being the dominant one. Group delay doesn’t hit the 1 cycle limit until at very low frequencies. There’s quite a lot of excessive ringing around the tuning frequency/high pass at ~20 Hz. It could pull through the 100 dB level in spectral contamination test, but not without a really high overall distortion.
+ Very good extension
+ Flat frequency response
+ Extremely low upper bass distortion at all levels
+ Steep crossover
+ Build quality and sturdy enclosure
- Medium deep bass maximum output capability
- High deep bass distortion at higher than medium output levels
- Some ringing around the tuning frequency
- Somewhat expensive compared to performance
Forum Rules
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived »
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
