Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived
Proson Stratego Sub 12+
Discuss Proson Stratego Sub 12+ in the Manufactured Speakers and Subwoofers forum; Proson Stratego Sub 12+ Manufacturer: Proson Model: Stratego Sub 12+ Provided by: Luoti Manufacturer link: Proson - Proson Stratego Sub 12+ Price: 320 EUR ...
Alphabetical Search
All # A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
 Closed Thread     Post New Thread
Views: 3535 - Replies: 3
Old 07-16-06, 03:48 PM   #1
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Provided by: Luoti
Price: 320 EUR
Manufacturer specs:
• Construction: Slotted Bassreflex in back
• Woofer: 12-inch long-throw
• Frequency Response: 22 - 150 Hz
• Crossover Frequency: 50 - 150 Hz
• Max Power: 300 W
• R.M.S. Power: 180 W
• Low level in/out
• High level in and filter out
• Volume control
• Variable lowpass filter
• Variable phase 0/180
• On-auto-off switch
• Size (HxWxD): 550 x 381 x 500 mm
• Weight: 27.5 kg
Configuration as tested:
Phase: 0 degrees
Orientation: Sideways
Forum Rules
Old 07-17-06, 11:19 AM   #2
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
+/- 3 dB points: 33.5 Hz - >200 Hz
Forum Rules
Old 07-17-06, 11:19 AM   #3
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Forum Rules
Old 07-17-06, 03:21 PM   #4
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Doesn't go extremely deep, although the final roll off is rather shallow for a vented subwoofer. The built-in crossover isn't really useful with its ~100 Hz minimum setting, which will definitely cause a lot of mid/upper bass bloom. Useful mid bass maximum output goes all the way up to 105 dB. Deep bass output is rather limited at around 80-90 dB. THD stays really low down to 30 Hz, but skyrockets below. 110 dB sweeps shows severe amp clipping. Group delay is really low at all frequencies. Spectral decay shows only little ringing. Spectral contamination tests shows rather high maximum output capability, but with high overall distortion. The overall build quality follows the price of the subwoofer.
+ Good shape of the frequency response for smaller rooms
+ High and clean upper bass maximum output capability
- Extremely bad built-in crossover
- Weak extension
- Low deep bass output
- Really high deep bass distortion
Forum Rules
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived »
Dish Network
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327
