Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived
SVS PB12-Plus/2 20 Hz tune (dB12.1)
Discuss SVS PB12-Plus/2 20 Hz tune (dB12.1) in the Manufactured Speakers and Subwoofers forum; SVS PB12-Plus/2 20 Hz tune (dB12.1) Manufacturer: SVSound Model: PB12-Plus/2 Provided by: JaniH Manufacturer link: SVSound - Box Subwoofers Price: $1199 (black), $1399 (wood veneer) (dB12.1 ...
Alphabetical Search
All # A B C D E F G H I J K L M N O P Q R S T U V W X Y Z
 Closed Thread     Post New Thread
Views: 4034 - Replies: 6
Old 07-16-06, 03:55 PM   #1
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Model: PB12-Plus/2
Provided by: JaniH
Price: $1199 (black), $1399 (wood veneer) (dB12.1 woofers not available anymore)
Manufacturer specs:
Proprietary TC-Sound 12" high output woofers
SVS designed, full-featured 900 watt BASH (R) digital switching amp
Premium finishes ship with on board Parametric EQ (PEQ)
Built-in, flush-mount amp configuration
Down-firing woofers with distinctive SVS integrated base-plate
Compliant floor mounts, ultra low center of gravity
Three tuned, patented 4" high-flow flared porting (in and out)
Assembled and tested by SVS in its Ohio factory
Extra heavy-duty detachable 8 foot power cord
6 wood-finishes
Selectable 16Hz, 20Hz or 25Hz extension with included port plugs
Size: 48 cm wide, 67 cm tall and 71 cm deep.
Weight: 64 kg
Frequency Response: +/- 3dB to 20hz anechoic
3 years warranty
Configuration as tested:
Phase: 0 degrees
Tuning frequency: 20 Hz (one port plug)
Subsonic filter: 20 Hz
Orientation: Standard down-firing, ports facing left
This unit has dB12.1 woofers
Forum Rules
Old 07-17-06, 11:27 AM   #2
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
+/- 3 dB points: 18 Hz - 110 Hz
Forum Rules
Old 07-17-06, 11:27 AM   #3
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
Forum Rules
Old 07-17-06, 03:16 PM   #4
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
The shape of the frequency response becomes a bit better when plugging one of the ports, though there is still some excessive deep bass output. There is around 5 Hz more extension due to this operation. The maximum deep bass output will get higher at the expense of mid/upper bass output. The deep bass output is still clearly limited by the port area (2x4"). THD stays quite low close to the tuning frequency, though rising quite a lot in the upper bass range at the highest output levels; luckily it’s mainly 2nd order. Group delay stays low down to 30 Hz, but grows rapidly below. Spectral decay shows a lot of ringing around the tuning frequency. Spectral contamination test shows high output capability with lower than average overall distortion, though a little bit worse than with the 25 Hz tune.
+ Good extension
+ High overall maximum output capability
+ Low overall distortion
+ Overall price/performance ratio
- Shape of the frequency response
- High deep bass output compression
- High upper bass distortion at high output levels
- High deep bass group delay and ringing around the tuning frequency
Forum Rules
Old 04-21-08, 04:32 PM   #5
Alias: Andrey
Loc: Portland
User: #1571
  tpaxadpom is offline
Re: SVS PB12-Plus/2 20 Hz tune (dB12.1)
Ilkka,
do you recall subwoofer build date? Mine was built in 2004. I e-mailed SVS to find out what version of woofers I have. Ed from SVS responded almost right away. According to him all PB12-Plus/2 subs were built with 12.2 woofers.
Forum Rules
Old 04-30-08, 08:16 PM   #6
Alias: Andrey
Loc: Portland
User: #1571
an update to the previous post. I confirmed that my unit has db12.1 drivers.
Forum Rules
Old 05-16-08, 01:23 PM   #7
Alias: Ilkka
Ilkka's Avatar
Loc: Finland
User: #991
Since: Jun 2006
  Ilkka is offline
tpaxadpom wrote: View Post
Ilkka,
This particular subwoofer was also built in 2004. IIRC the driver upgrade was made around January 2005.
Sounds correct.
Forum Rules
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests - Archived »
