| Subwoofer Tests LMS-5400 buy-inDiscuss LMS-5400 buy-in in the Manufactured Speakers and Subwoofers forum; LMS-5400 buy-in It would show up in their FR then.
Oh but it does show up in a measurement. Here are two ... |
| | #176 (Link) | ||||||
| Re: LMS-5400 / RL-p18" buy-in Quote:
![]() ![]() Quote:
Now yeah, the rolloff in the last graph you posted is certainly not bad. Only ~4dB down at 100Hz, right? Still there though...so I guess all I am saying is...blaming others thoughts about the Ava's lack of punch on their penchant for higher distortion may not be entirely correct. It could be...but I think the ava's roll off also may be a good portion of it. We've yet to be given a reason to think the Ava has abnormally good upper frequency response. Quote:
| | #177 (Link) | ||||
Now that said, again, I have't observed such dropoff in upper bass myself, and I know my VR3s don't have humped bass above 100hz which could be making up for it. My response up to 200hz was extremely flat in the old place - haven't measured it at this new place. Also, I'm not necessarily "blaming" others' perceived lack of punch on low distortion, as I just remembered after your post that they both have pretty bad in room FRs. | ||||
| | #180 (Link) | |||||||
But the fact that those measurements I linked to are only of the sub driver doesn't negate them, if anything they are more useful. Their deficiencies can't be masked. If a roll off exists, it will show up. Quote:
"It would be nice to see an Avalanche 18 measured because some owners are saying there isn't enough punch in the higher frequencies. I have to think that be because it is clean near the top, and they want that synthetic punch." You say it is clean near the top but how clean, relative to what, and where is the evidence? Quote:
Just things to think about. | |||||||
| | #181 (Link) | |||||
| Re: LMS-5400 / RL-p18" buy-in That measurement was with an 80hz crossover, I only switched to 60hz after moving to this new place. FR of the VR3s is the purple line. ![]() I've measured them to be flat to 30hz in room. Quote:
| | #182 (Link) | |||
| Re: LMS-5400 / RL-p18" buy-in A few comments: Ilkka is right on the money about the TC woofers having a more linear compliance (because of their 10" spiders with deep rolls) and this having an effect on the distortion measurement below resonance. However, if you have a spider that is more linear in one direction than another (which is many times the case) and you mirror image them, while things can be a little more symmetrical, you kind of get the worse of both rather than the best. I think this was Dan’s main point along with the idea that it doesn’t help rocking as much as is though but that may be debatable. Obviously the LMS 4" diameter >3" long coil with an average of >4 layers will have higher self inductance (and issues with modulation distortion etc) than a 3" diameter ~1.5" long 4 layer coil like an SDX15 or Tumult. What you're seeing in the 5400 is a difference in implementation of shorting rings etc., not proof that there isn’t an issue with this with the LMS design. The tough thing about shorting rings is that hey are not effective at low frequency without being really thick. Also, if you sleeve the pole (TC mentions using a 4.5" long copper sleeve) you're making an already very wide gap even wider (since copper has about the same DC permeability as air), further reducing the flux density which makes low frequency modulation distortion even worse. In short, it looks like TC was only able to get good performance with that huge motor structure (4 ~11" OD magnets and 4" coil) to get the Q back down to reasonable. The Eclipe 8200 has shorting rings are reasonable performance but isn’t really well suited to its application (Mms too high, BL too low). And really needs the larger magnet etc. Basically, we're seeing more of an issue with differences in implementation and so you really cannot make accurate blanket statements about the technology. With XBL^2, the rebate between the top plates is a natural place for a shorting ring (and a fairly thick one can be put there) without lowering flux density in the gap and adding a lot of cost. Ideally, additional shorting rings or a sleeve on the pole need to be implemented to balance things throughout the stroke of the driver. However, since you have two gaps, it requires a lot of magnet to get the BL high enough and so you see a lot of 4 layer coils and such is all of the subs. Of course the best way to address the inductance issue is to have most of your BL coming form B and with a huge magnet system like the 4 HP (or some big Neo thing) you I'd be curious to see an XBL^2 driver with a longer 1-2 layer coil take on a super woofer. The inductance graph shown by Dan is a simulation, not a measurement. However, you can see the effect of the shorting ring near the rest of the driver (i.e. between the top plates) and how it is effective more at higher frequency than lower. Of course, inductance increases inward into the motor because of the presence of more steel (making the coil essentially iron core instead of air core). In reality, things mighty be a hair better than this measurements because of some/most of the steel being in saturation, as this sim isn’t taking into account the relative DC permeability. The Klippel inductance result isn’t at all directly comparable. It is a lumped model which is somewhat skewed by the low frequency side of things (required to get the high displacement). In short, if you make this graph flat, you could be putting too much copper in the motor (making the curve very non-flat in the range where the copper is effective). This is the case with some drivers like the Eminence Magnum and probably also some of the PE stuff. The Ascendant Avalanche uses the exact sample coil and gap dims as a Brahma. They used a softer spider and use a slightly shorter different magnet (short magnet with a large bumped back plate) but I’d expect the distortion performance to be basically identical (i.e. no revelation with the AVA15 tests). It’s a round wire coil that ~20% shorter than a Tumult and inductance, Max and power handling is a bit lower but they are really more similar than different. Basically, yhere is a lot more to the total picture and root causes than most understand (including myself) but some guys here know enough “to be dangerous” and campaign in a certain direction that is somewhat misleading. | |||
| | #183 (Link) | ||||||
| Re: LMS-5400 / RL-p18" buy-in Hi Chris, Hopefully you don't mind me mentioning that you used to work for Adire Audio, so that people know where we're coming from. ![]() As you have probably noticed, I'm more of facts and objective data than marketing talk type of guy. I have no business interests towards any manufacturer making complete HT subwoofers or just drivers for them/car audio. Therefore I also do not campaign in any certain direction, other than towards good performance. Whether that road leads to TC Sounds, JL Audio, SVS, CSS, or any other company, doesn't really matter to me at all. Quote:
Measurements show extremely low THD and very flat upper-end frequency response for the LMS coil. In the end that is much more important than just saying that the other design must have lower inductance due to shorter VC. Quote:
![]() Quote:
| | #184 (Link) | ||||
| | #185 (Link) | ||||
| | #186 (Link) | |||
| Re: LMS-5400 / RL-p18" buy-in I did mention on the other thread that I did work for Adire and don't mind you mentioning it. Of course I haven't worked there is a couple of years but still am working the the speaker business at another company. However, I would think that this would help m credibility not hurt it, as I have had a lot of experience with these sots of drivers. I'm not a hardcore engineering type and know more than some but an still in the "enough to be dangerous" category as well. I just think it is a mistake to come to conclusions about a particular technology or approach like LMS or XBL^2 from the particulars of a given driver and many times the dominant factors are the particular execution and trade-offs made. A avalanche is essentially a Brahma and so isn't between a Tumult and 5400 at all. Tumult is is its bigger brother with significantly high power handling and stroke and BL but with somewhat higher inductance as well. The 5400 is something different altogether. There are some measurements of a Brahma 12" based ported woofer in Keith Yates "way down deep" article here: http://www.ultimateavmag.com/feature...ay/index1.html As you can see, it is similar to the Tumult with less output but also a little less upper end modulation distortion. Still, that inductive hump is there. Klippel has real problems with a Brahma / AVA as these drivers as they are suspension limited enough that you can't get a proper BL curve fit. I don't think it will tell you what you're looking for and the distortion measurement approach is probably better. Last edited by Chris Brunhaver; 09-22-07 at 10:52 PM. | |||
| | #187 (Link) | ||||
![]() If yes, may I enquire which driver does then? | ||||
| | #188 (Link) | ||||
On top of that, when you take the price tag of the Tumult into account, based on Ilkka's tsting, I'd be nice if I said the performance wasn't exactly stellar. | ||||
| | #189 (Link) | ||||||
"New for the Mark II design is an integrated shorting ring, lowering inductance even further and drastically lowering flux modulation. " But who knows how significant the difference really is? Quote:
![]() Doesn't quite match up to Ilkka's measurements does it? Maybe we shouldn't go around posting our measurements taken by RS meters as the absolute truth. ![]() Quote:
| | #190 (Link) | |||
| Re: LMS-5400 / RL-p18" buy-in Illka, Are the enclosure/s for the LMS's done? Do you know what alignments you'll be going with and can you give an estimate of when the outdoor testing will take place? Sorry if you've already stated all of this info before. | |||
| | #191 (Link) | ||||
All of these use fairly high inductance copper coils and the Brahma / Avalanche could have used shorting rings and we gapped a little wide (though not as bad as a Tumult, which was gapped for an 8 layer flat wire aluminum RE XXX coil). At least the SDX15 has a shorting ring (to address this somewhat) but this could probably be improved somewhat (at a cost). The Mark II Tumults were quite similar to the SDX15 (with a hair bigger magnet) and the same comments apply. I didn't really get a chance to play with these (though a friend has one) but I don't think they had as good a spider or as rugged a build quality as the originals. The Avalanche 18 was under motored, as is the new stuff from DIYcable. Steve, I'm glad you like your 20+ cubic foot EBS enclosure but I'll pass. This, in part, is why Adire didn't do one (i.e. Tumult of Brahma 18) and also that slow Maelstrom sales had scared them away from 18's. Probably the best implemented XBL^2 design were the CSS FR125S (though it could use a bit more magnet and better shorting ring implementation) and RE XXX 6 (he original Extremis) which had the an awesome motor design though the mass was a bit high and soft parts ho-hum. For subs, the Blueprint 01 (w/ XBL^2) / Koda motor was a pretty elegant solution. With some shorting rings and a bigger magnet, this 22 mm top plate ~16 mm Xmax solution was a bit of a sweet spot. That is of course just my $.02. While they are cool to talk about and get a lot of attention, I'm not really in favor of the single huge subwoofer and would rather do a few smaller subs spaced throughout an HT. Last edited by Chris Brunhaver; 09-23-07 at 06:22 PM. | ||||
