Bk XLS200-DF MK2 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Bk XLS200-DF MK2
Discuss Bk XLS200-DF MK2 in the Manufactured Speakers and Subwoofers forum; Bk XLS200-DF MK2 Manufacturer: BK Electronics Model: XLS200-DF MK2 Provided by: vese Manufacturer link: BK Electronics Price: 525 EUR Manufacturer specs: • System ...
Old 07-30-07, 12:07 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Bk XLS200-DF MK2
Provided by: vese
Price: 525 EUR
Manufacturer specs:
• System Type: Critically Damped Active System with Variable Freq bass filter and 18 litre Sealed Enclosure
• Frequency Response at -6dB: 17Hz
• Amplifier Input / Output Impedance: High Level 100K - Low Level 10K
• Gain Control Range: 60dB
• Drive Unit Impedance: 4 Ohm
• Mains Input: 230V / 50Hz
• Dimensions: 340D X 355H x 290W
• Weight: 17.5kg
• Finishes: Black Semi Gloss, Silver Semi Gloss, Light Oak Veneer and Cheery Veneer
• True 275W continuous discrete Bipolar amplifier
• Truly hand built in Great Britain, when we claim hand built we mean hand built, as there are no SMD components or other automatic placement devices
• Forward Firing 250mm (10") Peerless XLS10 long throw heavy duty and highly regarded drive unit
• Continuously variable frequency control
• Audiophile grade toroidal transformers
• Gas Tight Neutrik connection for long term consistency of sound quality
• Separate controls for high and low-level input adjustment
• Simultaneous connection of high and low level sources
• ASP automatic speaker protection audibly transparent driver protection
• 4 x 16A output devices for effortless current control
• IEC Power Socket
Configuration as tested:
Phase: 0 degrees
Crossover: Bypassed
Orientation: Standard down-firing
Old 07-30-07, 12:07 PM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Bk Xls200-df Mk2
+/- 3 dB points: 38.5 Hz - >200 Hz
Old 07-30-07, 12:07 PM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:08 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:08 PM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:08 PM   #6 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:08 PM   #7 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Reserved
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
HSU VTF-3 MK2 (maximum extension) Ilkka Subwoofer Tests 4 03-30-07 06:14 PM
HSU VTF-3 MK2 (maximum output) Ilkka Subwoofer Tests 3 07-17-06 02:23 PM
Mach 5 Audio
