DIY Adire Audio Tumult 15" MK1 sealed 100L - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Discuss DIY Adire Audio Tumult 15" MK1 sealed 100L in the Manufactured Speakers and Subwoofers forum; DIY Adire Audio Tumult 15" MK1 sealed 100L Manufacturer: DIY Provided by: mappe Manufacturer link: - Price: - Manufacturer specs: • Woofer: Adire Audio Tumult 15” MK1 (DVC ...
Old 07-30-07, 12:10 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Manufacturer: DIY
Provided by: mappe
Price: -
Manufacturer specs:
• Woofer: Adire Audio Tumult 15” MK1 (DVC 2x2 ohm)
• Amplifier: Yamaha M-85 (~2x600 W @ 2 ohm)
• Enclosure: 100 liters, 50 mm MDF, braced
Configuration as tested:
Phase: No control
Crossover: No control
Orientation: Woofer facing the mic
Old 07-30-07, 12:10 PM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: DIY Adire Audio Tumult 15" MK1 sealed 100L
+/- 3 dB points: 27 Hz - 77 Hz
Old 07-30-07, 12:10 PM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:10 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:10 PM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:11 PM   #6 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:11 PM   #7 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Reserved
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
DIY Sealed 15" Soundsplinter RL-P15 Subwoofer FlashJim SoundSplinter 109 11-20-07 09:10 AM
12" Sub for sealed enclosure Pupton DIY Subwoofers - Sealed and Ported 8 01-31-07 08:57 PM
need help on sub diy IB ported sealed jacoviii DIY Subwoofers 0 10-07-06 05:31 PM
Sealed 3.9ft^3 Tumult Project Exocer DIY Subwoofers - Sealed and Ported 64 09-12-06 09:07 PM
My sealed 12" nearfield measurements. Exocer Home Audio Subwoofers 1 05-24-06 08:26 PM
Mach 5 Audio
