Axiom EP-600 (1st test) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Discuss Axiom EP-600 (1st test) in the Manufactured Speakers and Subwoofers forum; Axiom EP-600 (1st test) Manufacturer: Axiom Audio Model: EP-600 Provided by: Ilkka Manufacturer link: Axiom Audio Price: $1780 Manufacturer specs: • Enclosure: Vortex / ...
Old 08-19-07, 08:10 AM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Model: EP-600
Provided by: Ilkka
Price: $1780
Manufacturer specs:
• Enclosure: Vortex / Reflex
• Max Amp Power: 600 Watts
• Cross-over Adjust: 40-100 Hz
• Phase: 0 & 180
• Woofer Size: 12”
• DSP Controlled: Yes
• Line In and Out: Yes
• Balanced Line In and Out: Yes
• High Level In: Yes
• Room Trim: Yes
• Dynamic Power Supply: Yes
• Boost Control: Yes
• Anechoic Resp. +/- 1.5dB: 19-100 Hz
• Anechoic Resp. +/- 3dB: 17-100 Hz
• Room Resp. + 3dB/- 9dB: 15-100 Hz
• Max SPL Anechoic: 111 dB
• Max SPL In Room: 122 dB
• Dimensions HWD mm: 1156 x 381 x 432
• Dimensions HWD inches: 45½ x 15 x 17
• Weight lbs each: 103.4 lbs
• Weight kg each: 46.901 kg
Configuration as tested:
Phase: 0 degrees
Low pass filter: Bypass
EQ/Room Trim: Flat
Front grill removed
Orientation: Horizontal
Old 08-19-07, 08:10 AM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Axiom EP-600 (1st test)
+/- 3 dB points: 18 Hz - 98 Hz
Old 08-19-07, 08:11 AM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 08-19-07, 08:11 AM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
For THD data see 2nd test.
Old 08-19-07, 08:11 AM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 08-19-07, 08:11 AM   #6 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
The frequency response is quite flat in 20-100 Hz range but is filtered steeply away above and below. The crossover can not be disabled which should be noted if any higher than 100 Hz crossover is required. Otherwise the crossover works as promised. The maximum output compresses heavily everywhere else than in 30-50 Hz range. It sort of reminds of a band pass subwoofer, but in fact is done by active DSP limiting. One could ask a little bit more output from such an expensive and also rather large subwoofer. Axiom’s output limiters work very efficiently and won’t allot any kind of strange noises out of the subwoofer. There is some “port chuffing” near the maximum output, but not much. There was some controversy regarding the distortion measurements so I decided to re-test it later in order to rule out any human error. Please see the 2nd test thread for additional info. The group delay stays low down to 40 Hz but grows rapidly below. It exceeds the 1 cycle limit at 29 Hz. The sudden and abrupt change in phase may be heard as slightly delayed lowest notes. As one could imagine by looking at the frequency response plot, there’s quite a lot of ringing around both steep slopes at 20 Hz and 100 Hz.
The Axiom EP-600 is sort of a strange bird. It’s obvious that a lot of engineering was poured into this subwoofer; it only seems that some aspects weren’t necessarily considered carefully enough. The amplifier is a very sturdy class D unit with a conventional analog power supply, and the woofer itself has a large 3” dual voice coil, so the basics are in order. The enclosure could be a little bit more rigid; now the panels are only 3/4" thick and the internal braces are spaced too far away from each other.
+ Relatively flat frequency response
+ High output in 30-50 Hz range
+ Good/inaudible output limiters (active DSP)
+ Small footprint when placed vertically
- High distortion at all frequencies
- High power compression
- High group delay and slow decay rate at low frequencies
- Somewhat weak enclosure
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
1st attempt at REW cburbs REW Forum 40 02-06-08 05:22 PM
Paradigm Monitor 11 vs Axiom M60/M80 alexadams77 Home Audio Speakers 23 11-25-07 02:44 PM
Axiom EP-600 (2nd test) Ilkka Subwoofer Tests 11 09-10-07 10:50 AM
test tust test DrPainMD Testing 4 03-30-07 09:03 AM
1st graph (before) union1411 REW Forum 6 05-14-06 05:40 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
