| Subwoofer Tests SVS 20-39PC+ 12 Hz tune (Plus 12.3)Discuss SVS 20-39PC+ 12 Hz tune (Plus 12.3) in the Manufactured Speakers and Subwoofers forum; SVS 20-39PC+ 12 Hz tune (Plus 12.3) Manufacturer: SV Sound
Model: 20-39PC+
Provided by: geecb
Manufacturer link: SV Sound , L-Sound
Price: $899
Manufacturer specs:
• SVS ... |
| | #1 (Link) | |||
| SVS 20-39PC+ 12 Hz tune (Plus 12.3) Manufacturer: SV Sound Model: 20-39PC+ Provided by: geecb Manufacturer link: SV Sound, L-Sound Price: $899 Manufacturer specs: • SVS designed/built custom Plus 12.3 woofer • Computer Assisted Design (CAD) enclosure • Flush mounted, 525 watt BASH amp • Exclusive down-firing cylinder design • Compliant floor mounts, low center of gravity • "Tri-Power" 3" high-flow ports with port blocks • User variable tuning: 20 Hz (stock) 16 and 12 Hz • Resonance free, protective top grill • CNC'd, black laminated, 1.5" birch end-caps • Architectural-grade black fabric exterior • Response: +/- 3dB 20-100 Hz (20 Hz config) • Size: 40" tall, 16" diameter • Weight : 55 lbs Configuration as tested: Phase: 0 degrees Tuning frequency: ~11 Hz (two port blocks) Crossover: Bypassed Orientation: Standard down-firing, ports facing the sky ![]() | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| SVS 20-39PC+ 20 Hz tune (Plus 12.3) | Ilkka | Subwoofer Tests | 9 | 02-27-08 05:26 AM |
| SVS 20-39PC+ 20 Hz tune (dB12.1) | Ilkka | Subwoofer Tests | 5 | 08-19-07 08:22 AM |
| SVS 20-39PC+ 16 Hz tune (dB12.2) | Ilkka | Subwoofer Tests | 5 | 08-19-07 08:20 AM |
| SVS 20-39PC+ 20 Hz tune (dB12.2) | Ilkka | Subwoofer Tests | 5 | 08-19-07 08:19 AM |
| SVS 20-39PC+ 16 Hz tune (Plus 12.3) | Ilkka | Subwoofer Tests | 8 | 08-02-07 10:25 AM |
