SVS PB10-ISD (2nd unit) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Discuss SVS PB10-ISD (2nd unit) in the Manufactured Speakers and Subwoofers forum; SVS PB10-ISD (2nd unit) Manufacturer: SVSound Model: PB10-ISD Provided by: Ilkka Manufacturer link: SVSound - Box Subwoofers (has been replaced by identically performing PB10-NSD ...
Old 07-16-06, 02:54 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Model: PB10-ISD
Provided by: Ilkka
Manufacturer link: SVSound - Box Subwoofers (has been replaced by identically performing PB10-NSD model)
Price: $429
Manufacturer specs:
• Proprietary SVS-designed long-throw 10" woofer
• 300 watt BASH digital switching amp
• Computer aided cabinet design with 1" front baffle
• Front-firing design with flush fit woofer and vent
• Patented 3" wide-flare port fittings
• Six removable, compliant floor isolation points
• Four finish choices to match any décor
• Color-keyed fabric grill with chromed mounting pins
• Extra heavy-duty, removable 8 foot power cord
• Contemporary, "seamless" cabinet styling
• +/- 3dB from 20-100 Hz anechoic, in room extension will be 2-5 Hz deeper
• Size: 15 ½" wide x 19" high x 21 ½" deep
• Weight: 60 pounds
• 220~240V 50/60Hz configuration available
Configuration as tested:
Phase: 0 degrees
Orientation: Woofer facing the mic
This is not the same unit which was tested last fall
Old 07-17-06, 10:24 AM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
+/- 3 dB points: 18 Hz - 150 Hz
Old 07-17-06, 10:25 AM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-17-06, 02:18 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
The cheapest and smallest one of the SVS offerings (at the time). When considering that, it's kind of surprising that it has the flattest frequency response of the SVS subwoofers I have tested. A small hump at 60 Hz and a slope above it doesn't look that bad. The shape of the frequency response suits better for larger rooms having not much deep bass room gain. Otherwise the sound may become too bottom heavy. The PB10 doesn't have a built-in crossover, so a traditional 2-channel use won't work without an external crossover. The maximum output, both mid and deep bass, is relatively high for a 10" subwoofer. It breaks the 100 dB barrier at all frequencies above 25 Hz. A single 3" port and a high output won't come without expenses - there is quite audible port noise at high output levels. THD profile is rather strange with much higher than typical THD above 40-50 Hz; luckily it’s mainly low order distortion. Group delay stays low down to 30 Hz, but goes quickly well above the 1 cycle curve below. Spectral decay shows a lot ringing around the tuning frequency. Spectral contamination test shows average maximum output capability with higher than average overall distortion. The black vinyl finish looks somewhat cheap. The overall build quality is above average.
+ Good extension
+ Good frequency response for larger rooms
+ Relative high overall maximum output capability
- High upper bass distortion
- High deep bass group delay
- Slow deep bass decay rate
- No crossover
Old 02-13-07, 12:45 AM   #5 (Link)
Alias: Tucker76
Loc: St Louis Mo (City)
User: #5722
Since: Jan 2007
stlfdemt is offline
Re: SVS PB10-ISD
that is my sub
Old 05-17-08, 08:24 PM   #6 (Link)
Alias: Thomson
Loc: Oklahoma City, OK
thomson405's Avatar
User: #20602
Since: May 2008
thomson405 is offline
Re: SVS PB10-ISD
I just ordered the PB10-NSD
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
Face-Off - SVS PB10-ISD Takes On A Few Contenders Wayne A. Pflughaupt Home Audio Subwoofers 24 06-04-08 12:25 PM
SVS PB10-ISD (sealed) Ilkka Subwoofer Tests 5 08-19-07 08:34 AM
SVS PB10-ISD (1st unit) Ilkka Subwoofer Tests 5 08-19-07 08:32 AM
Face-Off - SVS PB10-ISD Takes on a Few Contenders Wayne A. Pflughaupt SVSound 4 04-29-07 09:07 PM
PB10-ISD on Clearance JCD SVSound 0 06-01-06 02:06 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193
