Monitor Audio BRW10 - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Monitor Audio BRW10
Discuss Monitor Audio BRW10 in the Manufactured Speakers and Subwoofers forum; Monitor Audio BRW10 Manufacturer: Monitor Audio Model: BRW10 Provided by: vese Manufacturer link: Monitor Audio Price: 559 EUR Manufacturer specs: • Low frequency ...
Old 07-30-07, 12:42 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Monitor Audio BRW10
Model: BRW10
Provided by: vese
Price: 559 EUR
Manufacturer specs:
• Low frequency limit: 27Hz
• Upper frequency limit: 40 – 120 Hz
• Variable Low pass filter alignment: 4th order 24db/octave
• Amplifier Output: 150 Watts (R.M.S)
• Amplifier classification: Class- D Digital amplifier
• Driver compliment: 1 x 10” MMPฎ II long throw driver
• Dimensions: Millimetres 320 H x 320 W x 340 D Inches 12 5/8 x 12 5/8 x 13 3/8, All dimensions excluding grille
• Weight (unpacked): 12.5 Kg (27.5lbs)
• Input Impedance: 20K Ohms
• Mains input voltage: 115 Vac / 230 Vac Factory Preset. Do not adjust
• Finishes: Black Oak, Cherry and Walnut vinyl’s. All fitted with a black grille.
Configuration as tested:
Phase: 0 degrees
Crossover: Max
Orientation: Woofer facing right, port facing left
Old 07-30-07, 12:42 PM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Monitor Audio BRW10
+/- 3 dB points: 47.5 Hz - 105 Hz
Old 07-30-07, 12:43 PM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:43 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:43 PM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:43 PM   #6 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-30-07, 12:43 PM   #7 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Reserved
Old 08-04-07, 12:15 AM   #8 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
What a POS
Old 08-04-07, 08:14 AM   #9 (Link)
Alias: Robert
Loc: Ny, NY
User: #17
Exocer is offline
SteveCallas wrote: View Post
What a POS
Yeah, I guess so. Clearly it doesn't offer much bang for the buck...or bang at all in comparison to many other similiarly priced subs.
If you don't have a BFD for your sub, get one fast!
If you don't have REW, get it now!
Old 08-04-07, 03:47 PM   #10 (Link)
Alias: Jacob
Loc: I ain't tellin ya!
User: #1688
soho54 is offline
Like you guys could do better for $766 US retail dollars. Please!
Really though, what is up with this sub?
The new BRW-10 is a perfect complement to any theater, adding grip and clean bass down to 27Hz.
Grip?
Maybe all that distortion makes it sound more High End. They could say it reveals parts of a track you never heard before. Maybe even with a straight face.
All kidding aside... With that distortion peak at 60Hz I bet it actually sounds decent at low levels. It should sound punchy, and people will ask how that much bass is coming from that little sub. The way people love my THX Logitech PC set up. "It sounds just like my car," they say.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
Monitor Audio RS1 mike c Home Audio Speakers 25 04-17-08 10:54 AM
FS: Monitor Audio Silver HT Josuah Classifieds - Speakers and Subwoofers 4 10-29-07 10:47 PM
Monitor Audio Bronze Reference BR2 A/B review mike c Home Audio Speakers 11 10-21-07 07:39 AM
Upgrading from Paradigm Monitor Series? Owen Bartley Home Audio Speakers 15 11-14-06 11:10 AM
Review: Monitor Audio GR10, GR Center and GRfx GregBe Home Audio Speakers 6 06-21-06 10:18 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
