Go Back   Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Register
Subwoofer Tests
SVS SB12-Plus
Discuss SVS SB12-Plus in the Manufactured Speakers and Subwoofers forum; SVS SB12-Plus Manufacturer: SV Sound Model: SB12-Plus Provided by: Ilkka Manufacturer link: SV Sound, L-Sound Price: 913 EUR (black), 973 ...
Old 07-30-07, 12:50 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
SVS SB12-Plus
Model: SB12-Plus
Provided by: Ilkka
Price: 913 EUR (black), 973 EUR (wood)
Manufacturer specs:
• SVS designed/built custom Plus 12.3 woofer
• Built-in 425 watt BASH (R) amp with PEQ
• CAD design, CNC cut hand-built enclosure
• Front-firing sealed design, recessed driver
• Compliant floor mounts, low center of gravity
• Room compensation control for optimal response
• Assembled and tested in the Ohio SVS factory
• Extra heavy-duty detachable 8 foot power cord
• Five finishes with intricately rounded corners
• Magnetic grill retainers (premium finishes only)
• Industry leading response (+/- 3dB 22 Hz-150 Hz)
• Size: Approx. 15” deep x 14" wide x 14" high, 35 cm wide x 35 cm high x 37.5 cm deep
• Weight: 40 pounds, 18 kg
Configuration as tested:
Phase: 0 degrees
Crossover: Bypassed
Room compensation control: Bypassed
Orientation: Woofer facing the mic
Old 07-30-07, 12:50 PM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: SVS SB12-Plus
+/- 3 dB points: 26.7 Hz - >200 Hz
Old 07-30-07, 12:50 PM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: SVS SB12-Plus
Old 07-30-07, 12:50 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: SVS SB12-Plus
Old 07-30-07, 12:50 PM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: SVS SB12-Plus
Old 07-30-07, 12:50 PM   #6 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: SVS SB12-Plus
Old 07-30-07, 12:51 PM   #7 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: SVS SB12-Plus
Reserved
Old 12-11-07, 04:48 AM   #8 (Link)
New Member
Alias: AyGee
Loc: Germany
User: #1025
Since: Jun 2006
AyGee is offline
Re: SVS SB12-Plus
Hi Ilkka,
is it possible to add the pros and cons for this sub? I think I am not so good in interpreting all the results as you are.
I think this sub has as good frequency response for smaller rooms. But is it accurate and "fast" enough for music use?
Thanks in advance
AyGee
Old 12-12-07, 06:19 PM   #9 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: SVS SB12-Plus
AyGee wrote: View Post
Hi Ilkka,
Thanks in advance
AyGee
Hi AyGee,
I have posted some quick comments over here.
The whole accurate and fast issue has more to do with the subwoofer setup, room acoustics and speaker/sub integration than the subwoofer itself. Meaning that the room your listening in or the setup you're using may make the subwoofer/bass frequencies sound slow and inaccurate, and that isn't directly the subwoofer's fault. I always recommend people to measure the low frequency response of their setup/room so that they know what is going on down there. If your room has a strong modal resonance for example at 50 Hz, every unequalized subwoofer in that room will sound slow and inaccurate, no matter if it's an SVS or a Velodyne. A frequency response measuring system and a good parametric EQ are very important things to buy when dreaming of a good sounding subwoofer/system.
The SVS SB12-Plus is definitely accurate and fast enough for any kind of music or with any kind of speakers. It doesn't have the deepest extension nor the highest output due to the physical limitations (very small enclosure), but it is still a very good subwoofer. Two of them would make a great stereo subwoofer system even for a larger space.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
You may not post new threads, nor post replies, nor post attachments, and you can not edit your posts.
vB code is On, Smilies are On and [IMG] code is On
Similar Threads
SVS SB12-Plus Subwoofer: The Mouse That Roars Wayne A. Pflughaupt Home Audio Subwoofers 32 05-02-08 03:15 PM
SVS SB12-Plus & PB12-NSD review - Lyd & Bilde (English version) L-Sound - Jan SVSound 4 12-16-07 01:41 PM
SVS SB12-Plus in a larger room davetroy SVSound 12 07-01-07 06:26 PM
SB12-Plus Subwoofer: The Mouse that Roars Wayne A. Pflughaupt SVSound 1 02-09-07 11:45 PM
Small Box Sub: SB12-Plus Woofer: Ships Early October 2006 Sonnie SVSound 18 09-17-06 03:15 PM
Video Products, Inc. Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
Parts Express: 10,000 Audio & Video Products     SonyStyle   Aperion Audio   Cambridge SoundWorks   Toshiba Direct   Philips   Parts Express: 10,000 Audio & Video Products
OneCall: Your Home Theater, Digital Camera, and HDTV Experts   Circuit City   Vanns.com Audio, Video and Electronics   Best Buy   6th Ave     Buy.com   J&R Computer/Music World
Click here for your favorite eBay items   uBid is the marketplace you can trust!   eCost.com   www.Abt.com   TigerDirectTigerDirect   Once You Know, You Newegg   Apple Store   Be-Direct
Shop at the World's Largest Music Gear Company!   ZZounds   GuitarCenter.com   Wal-Mart.com USA, LLCWal-Mart   RadioShack Logo   Batteries.com for Every Season and Reason   All Battery   BetterCables.com - Home Theater Cables
Netflix, Inc.   Blockbuster Online   Cinema Now   Creative Labs-Leader in Digital Entertainment   Abes   DHGate   X10.com Home Solutions   MCM Electronics - Parts and More!
PC Mall - Great Technology, Great Advice, Great Pr   MacMall - #1 Apple Direct Reseller   Target   ButterflyPhoto.com   TicketMaster   Purchase Tickets   Crucial.com   CD WOW!
Search Engine Friendly URLs by vBSEO 3.1.0
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173
