XTZ 99 W12 (maximum extension) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Discuss XTZ 99 W12 (maximum extension) in the Manufactured Speakers and Subwoofers forum; XTZ 99 W12 (maximum extension) Manufacturer: XTZ Model: 99 W12 Provided by: Marek Sound Manufacturer link: XTZ Price: ??? (not sold in Finland) Manufacturer specs: ...
Old 07-30-07, 12:51 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Manufacturer: XTZ
Model: 99 W12
Manufacturer specs:
• Construction type: Active subwoofer, Bass reflex gate or may be set as closed box.
• Room-Tuning: With 2pc of included bass-plugs you have 3 different character of sound.
• Dimensions: 350 x 400 x 500 mm (WxDxH), Foot +15 mm, Amplifier +45 mm
• Weight: 30.5 kg
• Frequency: 25-180 Hz +/-3 dB
• Power: 300W RMS in 4 ohm, 400W RMS in 2 ohm
• Terminal connection: Gold plated bi-wiring / banana plug / pole screw
• Woofer driver: 12", acoustically transparent high flow molded aluminium basket, 100 oz magnet, rubber suspension, treated non pressed paper con , weight 6,5 kg
• Colour: High glossy black painting (genuine piano painting), Black matt painting
• General Info: RCA Stereo low level input, XLR balanced input and high level
(speaker) input
• Phase adjustment 0 to 180 degrees
• Boundary frequency control
• Volume control
• Heavy duty screw terminal gold plated connectors
• EQ-switch
• High- pass switch
• Room tuning
• Adjustable frequency
• Anti-vibration rubber feet
Configuration as tested:
Phase: 0 degrees
Tuning frequency: ~27 Hz (one port plug)
Crossover: Max
EQ: Off
High pass: Bypassed
Orientation: Woofer and ports facing the mic
Old 07-30-07, 12:51 PM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Xtz 99 W12 Me
+/- 3 dB points: 31.5 Hz - 184 Hz
Old 07-30-07, 12:51 PM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Xtz 99 W12 Me
Old 07-30-07, 12:51 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Xtz 99 W12 Me
Old 07-30-07, 12:51 PM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Xtz 99 W12 Me
Old 07-30-07, 12:52 PM   #6 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Xtz 99 W12 Me
Old 07-30-07, 12:52 PM   #7 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Xtz 99 W12 Me
Reserved
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
XTZ 99 W12 (maximum output) Ilkka Subwoofer Tests 6 07-30-07 12:53 PM
Mach 5 Audio
