| Subwoofer Tests SVS PB12-Ultra 20 Hz tuneDiscuss SVS PB12-Ultra 20 Hz tune in the Manufactured Speakers and Subwoofers forum; SVS PB12-Ultra 20 Hz tune Manufacturer: SV Sound
Model: PB12-Ultra
Provided by: Ilkka
Manufacturer link: SV Sound
Price: $1199-$1399 (depending of finish)
Manufacturer specs:
| | #1 (Link) | |||
| SVS PB12-Ultra 20 Hz tune Manufacturer: SV Sound Model: PB12-Ultra Provided by: Ilkka Manufacturer link: SV Sound Price: $1199-$1399 (depending of finish) Manufacturer specs: • TV-12 "Ultra" woofer built by TC-Sounds exclusively for SVS • 525 watt BASH (R) amp with parametric equalizer (all finishes) • Flush-mount amp configuration (220 volt version available) • Computer Assisted Design (CAD) enclosure • Down-firing configuration with distinctive SVS integrated base-plate • Compliant floor mounts, low center of gravity • Variable 3" high-flow flared ports with CURVE tuning • Assembled in the Ohio SVS factory, each hand tested • Extra heavy-duty detachable 8 foot power cord • Real wood veneers with soft rounded corners, gloss or textured black • Selectable 20Hz, 16Hz or 12Hz extension (20Hz native) • Size Approx. 25”deep x 18"wide x 25"high • Weight 125 pounds Configuration as tested: Phase: 0 degrees Tuning frequency: 20 Hz (no port plugs) Subsonic filter: 20 Hz Orientation: Standard down-firing, ports facing right ![]() | |||
| | #6 (Link) | |||
| Re: SVS PB12-Ultra 20 Hz tune The profile of the frequency response is a little bit strange. It tilts down quite heavily above 40 Hz which can be a problem with higher crossover settings and in rooms with lots of low frequency room gain. The sound becomes too bottom-heavy when the frequency response rises too much toward the low end. The built-in PEQ can help a bit, but an external EQ is preferred. The crossover works as promised and is steep enough for regular 2-channel use. The -6 dB point is at 16.5 Hz which is a very respectable performance. The maximum output below 50 Hz is really high for a single 12” subwoofer, but the upper bass output could be a little bit higher. The output starts to compress at the highest sweep level, especially around the tuning frequency. This tells that the subwoofer is somewhat under ported even at its native tuning. Some audible port chuffing was heard at the highest test levels. The THD profile is really good. THD stays below 1% at low levels and doesn’t go over 10% until below the tuning frequency. The group delay grows pretty steadily towards the low frequencies, ending up crossing the 1 cycle limit at 25 Hz. The spectral decay graph shows around 160 ms of ringing around the tuning frequency; not the best ported subwoofer I’ve seen but not the worst either. The SVS PB12-Ultra is a good performer. It is also a very good-looking, though rather large, subwoofer. It really shines in clean output in 20-40 Hz range. The frequency response could benefit from some shaping, and also the upper bass output could be a little bit higher. + Very high output in 20-40 Hz range + Low distortion + Very good extension - Uneven frequency response - Medium upper bass output - High power compression around the tuning frequency - High group delay and slow decay rate at low frequencies | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| SVS PB12-Plus/2 20 Hz tune (dB12.1) | Ilkka | Subwoofer Tests | 6 | 05-16-08 12:23 PM |
| SVS PB12-Plus/2 20 Hz tune (Plus 12.3) | Ilkka | Subwoofer Tests | 21 | 03-24-07 06:38 PM |
| PB12-ISD compared to PB12-Ultra/2 ? | Malice | SVSound | 6 | 02-17-07 05:17 PM |
| SVS PB12-Plus/2 25 Hz tune (dB12.1) | Ilkka | Subwoofer Tests | 3 | 07-17-06 02:17 PM |
| SVS PB12-Plus/2 25 Hz tune (Plus 12.3) | Ilkka | Subwoofer Tests | 3 | 07-17-06 02:14 PM |
