SVS PB12-Ultra 12 Hz tune - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Discuss SVS PB12-Ultra 12 Hz tune in the Manufactured Speakers and Subwoofers forum; SVS PB12-Ultra 12 Hz tune Manufacturer: SV Sound Model: PB12-Ultra Provided by: Ilkka Manufacturer link: SV Sound Price: $1199-$1399 (depending of finish) Configuration as tested: ...
Old 08-19-07, 08:26 AM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Model: PB12-Ultra
Provided by: Ilkka
Phase: 0 degrees
Tuning frequency: 12 Hz (two port plugs)
Subsonic filter: 12 Hz
Orientation: Standard down-firing, ports facing right
NOTE: Only partial tests were taken due to time constraints
Old 08-19-07, 08:27 AM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: SVS PB12-Ultra 12 Hz tune
+/- 3 dB points: 10 Hz - 150 Hz
Old 08-19-07, 08:27 AM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 08-19-07, 08:27 AM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Due the lack of time, I performed only a limited battery of tests for the 12 Hz tuned version. I also feel that the subwoofer is seriously under ported in this configuration and isn’t the best use of the subwoofer. The frequency response extends down to 10 Hz (-6 dB), but there is a prominent hump in 25-50 Hz range. The group delay stays well below the 1 cycle limit all the way down to 15 Hz. As expected, the subwoofer rings the longest around its tuning frequency at ~11 Hz.
12 Hz tuned Ultra is the best choice to those in small rooms and lots of low frequency room gain. Though it should be noticed that the output capabilities at higher frequencies are reduced quite heavily. Therefore this lowest tune is geared towards music use.
+ Relatively flat frequency response
+ Extremely good extension
+ Relatively low group delay
- Slow decay rate at very low frequencies
- Reduced output above 20 Hz
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
SVS PB12-Ultra 16 Hz tune Ilkka Subwoofer Tests 5 08-19-07 08:25 AM
SVS PB12-Ultra 20 Hz tune Ilkka Subwoofer Tests 5 08-19-07 08:24 AM
SVS PB12-Plus/2 20 Hz tune (Plus 12.3) Ilkka Subwoofer Tests 21 03-24-07 06:38 PM
SVS PB12-Plus/2 25 Hz tune (dB12.1) Ilkka Subwoofer Tests 3 07-17-06 02:17 PM
SVS PB12-Plus/2 25 Hz tune (Plus 12.3) Ilkka Subwoofer Tests 3 07-17-06 02:14 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
