SVS PB10-ISD (sealed) - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Home Theater Shack SVSound: The Sound Authority in speaker and subwoofers!  The new PB13-Ultra and PC-Ultra subwoofers are astonishingly awesome! Ultimate Home Entertainment: Providing home theater seating and accessories such as popcorn machines and signage... at very affordable prices! Parts Express: The #1 Internet source for all your DIY and electronics needs! Axiom Home Theaters: Award winning Internet direct speakers and subwoofers! Creative Sound Solutions: Loudspeaker kits and components for subwoofers, midwoofers, woofers and full range speakers! Mach 5 Audio: Affordable Drivers: Australian supplier of car and home audio subwoofer drivers of exceptional value! Fi Audio: Infinitely amazing balanced high end musicality designed drivers! SoundSplinter: A purveyor of exceptionally high quality subwoofers with a price tag that isn't heavier than their subs! Sony Style: Sony Audio and Video products! Ascend Acoustics: Award-Winning Audiophile Quality Loudspeakers Made Affordable Via Direct Sales! Funky Waves: A great source for custom subwoofers and speakers at incredibly low prices! Aperion Audio: Award winning Internet direct speakers and subwoofers! GIK Acoustics: Home audio acoustics at its best... especially when you have help from the owners right here at the Shack!  Check out their very affordable acoustic panels! Discount Merchant:  If you need a replacement bulb for your video device... look no further... save big! Home Theater Shack Electronics Store: An Amazon store front specializing in audio and video electronics... and generally offering the lowest prices on the net!
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Discuss SVS PB10-ISD (sealed) in the Manufactured Speakers and Subwoofers forum; SVS PB10-ISD (sealed) Manufacturer: SV Sound Model: PB10-ISD Provided by: Jeje2 Manufacturer link: SV Sound , L-Sound Price: $429 Manufacturer specs: • Proprietary ...
Old 08-19-07, 08:32 AM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Model: PB10-ISD
Provided by: Jeje2
Manufacturer link: SV Sound, L-Sound
Price: $429
Manufacturer specs:
• Proprietary SVS-designed long-throw 10" woofer
• 300 watt BASH digital switching amp
• Computer aided cabinet design with 1" front baffle
• Front-firing design with flush fit woofer and vent
• Patented 3" wide-flare port fittings
• Six removable, compliant floor isolation points
• Four finish choices to match any dιcor
• Color-keyed fabric grill with chromed mounting pins
• Extra heavy-duty, removable 8 foot power cord
• Contemporary, "seamless" cabinet styling
• +/- 3dB from 20-100 Hz anechoic, in room extension will be 2-5 Hz deeper
• Size: 15 ½" wide x 19" high x 21 ½" deep
• Weight: 60 pounds
• 220~240V 50/60Hz configuration available
Configuration as tested:
Phase: 0 degrees
Orientation: Woofer and port facing left
Front grill removed
Port plug was used
Old 08-19-07, 08:33 AM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: SVS PB10-ISD (sealed)
+/- 3 dB points: 32.5 Hz - >200 Hz
Old 08-19-07, 08:33 AM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 08-19-07, 08:33 AM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 08-19-07, 08:33 AM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 08-19-07, 08:34 AM   #6 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Since so many people had asked about plugging the port of the PB10-ISD, I had to test whether there were more positive than negative effects. Naturally the shape of the frequency response changes drastically, the -6 dB point shifts up to 32 Hz which is a good thing if your room has lots of low frequency room gain and the normal open port version causes a rising response towards the low end. Naturally the low frequency maximum output is also reduced by around 6 dB. Up higher the max output stays similar with the ported version. The amount of distortion goes slightly higher, especially at lower frequencies, which naturally isn’t a good thing. The group delay stays below the 1 cycle limit all the way down to the test limit at 15 Hz. The amount of ringing is also cut down, though one can still see the effect of a high pass filter at around 19 Hz which can’t be disabled.
The artificially sealed PB10-ISD is a good option for those whose room has lots of low frequency room gain and who feel that the low end sounds a little bit too strong but don’t want to use any EQ to reduce it.
+ Good frequency response for smaller rooms
- Lower deep bass maximum output compared to ported version
- High distortion, especially above 40 Hz
- No crossover
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
Face-Off - SVS PB10-ISD Takes On A Few Contenders Wayne A. Pflughaupt Home Audio Subwoofers 24 06-04-08 12:25 PM
SVS PB10-ISD (2nd unit) Ilkka Subwoofer Tests 5 05-17-08 08:24 PM
SVS PB10-ISD (1st unit) Ilkka Subwoofer Tests 5 08-19-07 08:32 AM
Face-Off - SVS PB10-ISD Takes on a Few Contenders Wayne A. Pflughaupt SVSound 4 04-29-07 09:07 PM
PB10-ISD on Clearance JCD SVSound 0 06-01-06 02:06 PM
Mach 5 Audio
Electronics Retailer   Home Theater HDMI Receivers   HD-DVD   Blu-ray
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186
