| Subwoofer Tests Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME***Discuss Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** in the Manufactured Speakers and Subwoofers forum; Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Measuring conditions:
Air temperature: 10-12 C
Atmospheric pressure: ~1015-1020 hPa
Wind speed: 0-1 m/s
Weather: Cloudy
It’s not Christmas eve ... |
| Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** ![]() Measuring conditions: Air temperature: 10-12 C Atmospheric pressure: ~1015-1020 hPa Wind speed: 0-1 m/s Weather: Cloudy It’s not Christmas eve yet, but here’s an early Christmas present for all of you bass heads - the full results for round 5 of our subwoofer testing! Due to a very interesting line-up, these particular results have probably been waited for most anxiously since I started performing these tests back in 2005. Can’t blame though, the JL Audio Fathom f113, SVS PB13-Ultra, TC Sounds LMS-5400 and BK XLS300/PR, just to name a few, have been easily the most discussed subwoofers on the audio forums lately. Many of the results you can see here are very rare and unique. For example you can’t find as thorough performance measurements performed on a JL Audio Fathom f113 or a TC Sounds LMS-5400 based subwoofer anywhere in the whole wide world. I have made some small adjustments on how I present the results. From now on, I will show the +/-3 dB points (6 dB window) for both maximum and minimum crossover settings. This will help people to understand how the frequency response and usually also extension changes when using a lower crossover. There is also one totally new graph showing the CEA-2010 standard defined maximum clean output. The highest ever and lowest ever limits are showing the highest ever and lowest ever performance at each frequency among the subwoofers I have performed the CEA-2010 standard defined measurements (round 4 ->). I have changed the legend in the total harmonic distortion graphs to show Sweep 1, Sweep 2 etc. instead of 90 dB, 95 dB etc. This was done because many people were assuming that the sound pressure levels shown in the legend were absolute. Hopefully this change helps them to understand that one HAS TO look at the maximum output curves above to be able understand what really happens during those sweeps. The sound pressure levels are not absolute but they are affected by the frequency response and power compression instead! I have seriously considered whether the spectral contamination graphs provide enough useful information to majority of the readers. Therefore I won’t be posting them, at least for now. I have the data for all the subwoofers tested on round 5 so I can post them later if enough people will like to see them. But in my opinion the current battery of tests is large and versatile enough to show the true performance of each subwoofer. ![]() SVS wasn’t totally satisfied with the performance (frequency response) of the customer owned PB12-NSD I measured on round 4 so they decided to send me a factory fresh unit this time. They say that the new frequency response is ok. BK Electronics provided a final prototype of their upcoming Extreme subwoofer for me to be measured. Can’t say if the measured performance affected, but soon after I was informed that the Extreme won’t make its way into production – at least in the form I measured it. So therefore its results won’t be published. I would like to thank a few companies who have supported my tests. Of course the TC Sounds LMS-5400 test wouldn’t probably ever happen without the people who participated in the buy-in regarding the woofer. So my wholehearted thank you to you as well! Of course thanks are due to all the private persons who loaned their subwoofers. I’m not sure what I can say to Maukka about the pictures that hasn’t been already said? Thanks to the usual suspects a.k.a. Goodguy, geecb and mappe for helping me out with the arrangements regarding the test. One request: when mentioning these tests on another Internet forum, please mention HT Shack. If you only refer these as "Ilkka's tests" etc., people have no idea where to look at. So please use "HT Shack subwoofer tests" or "Ilkka's subwoofer tests at HT Shack". Thank you! The English language comments on the results are still being worked out, but interpreting these results shouldn't be that difficult. Of course it's always better to ASK instead of making wrong conclusions. Remember to look at the results as a whole instead of looking too much into a single graph. Links to subwoofers tested on this round: Anthony Gallo Audio Pro Level 110 BK XLS300/PR DIY CSS 2xSDX15 sealed 140L DIY CSS SDX15 sealed 100L DIY Servo v2 DIY TC Sounds LMS-5400 18" + 2x18" PR 200L DIY TC Sounds LMS-5400 18" sealed 100L DIY TC Sounds LMS-5400 18" sealed 100L LT Gradient Evidence MK2 JL Audio Fathom f113 SVS PB12-NSD SVS PB13-Ultra 20 Hz tune SVS PB13-Ultra 15 Hz tune SVS PB13-Ultra 10 Hz tune SVS PB13-Ultra sealed Velodyne SPL-1200 MK2 Yamaha YST-SW1500 No material may be reproduced in part or in altered form without permission. Copyright © 2007 Ilkka Rissanen and Mauri Eronen (pictures) | ||||
| | #3 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Merry Christmas indeed!!! NICE!!! ![]() | ||||
| | #4 | ||||
| Yes, thanks for the amazing effort and detail!!! ![]() ![]() ![]() Without inviting too much controversy, I'm very curious about your own personal impressions. Which one would you buy for yourself, representing the best cost/performance ratio? Feel free to PM me if you don't want to be that subjective in the forum. ![]() Merry Christmas and much thanks again!!! Dali Mentor 8/Vokal/Ikon Phantom 5.1; SVS pb13 Ultra; Sherbourn 7/2100A bridged 3 channels for 400+ watts to L/C/R & Onkyo 875 pre-pro & surround amp = Audio Heaven! ![]() Now about that projector... | ||||
| | #7 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** As always, you are the best in the biz Very appreciative for all the hard work and something new to talk about in the coming months. | ||||
| | #9 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Excellent work Ilkka... ![]() | ||||
| | #13 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Thanks Ilkka for all the hard work. Independent tests like this are always interesting. Bryan | ||||
| | #14 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Hi Chaps, thankyou for the fantastic reports Ilkka and thankyou to all at the shack for their help and advice to me a new member. God Bless and have a great Christmas Regards Stuart Angus | ||||
| | #15 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Hi Ilkka, Thanks you for this gift ! Amazing and usefull work, I try to advertise it in France. Have a nice Christmas. Best wishes Patrick | ||||
| | #16 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Bravo Illka! Looks like once again the DIY subs didn't disappoint. The SVS subs and the F113 put up some impressive measurements too. Thanks for doing these tests! | ||||
| | #18 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** I am a newbie to this forum however I think that this forum is the best. Thanks Illka for all of your hard work. I am not much for into the techcnical aspects of Home Audio but I do enjoy reading and learning as I go along. I to am curious as to your personal opinion on the JL Audio Fathom 113....I happened to buy one a month ago and recently as Dec 23rd actually got to calibrate it and use it and I was blown away. It has everything I think a sub should be. Feel free to sendind a PM. Merry Christmas to everyone!!!! Frank ![]() Infocus 7205,Da Lite Screen Outlaw 990/7700 B&W 804's mains,HTM3S center,3-DS7's surrounds,Fathom 113 subwoofer Sony 550 Blu-Ray player Sony 777 DVD player,Toshiba DVD player MX 3000 remote,Monster 3500,3600 conditioners Comcast, MIT & Monster cable http://community.webshots.com/user/rubbersoul662001 | ||||
| | #19 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Thanks as usual. I'd be interested in seeing the spectral contamination charts posted for all the subs if you have them. Now... was the JLA's distortion that audible? In other areas people have compared that sub to the Ultra... now I am doubting their ears ![]() | ||||
| | #21 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Once again, you have outdone yourself!!!! Thanks!!!! | ||||
| | #22 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** I tried it but the internal fuse blew right after the start (same thing happened during the AV Talk tests so I was sort of expecting it). Same thing happened during the 110 dB when using the sealed mode (at around 14 Hz). | ||||
| | #23 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Hi all, I'm heading out on a short New Year holiday so I won't be online for a few days. But when I'm back, I will tackle all the questions regarding the subwoofers measurements you have made. ![]() Happy New Year to everyone! | ||||
| | #24 | |||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Quote:
Okay. Thanks for the info. ![]() | |||||
| | #25 | ||||
| Re: Subwoofer Tests Round 5, 6th of October 2007, Test Summary ***READ ME*** Hi Ilkka, Do you have the means to measure/record amplifier and sub output distortion at the same time. For your next round of tests, it would be informative to see how much distortion/compression the amp is contributing along side the sub measurements. It seems like the CSS 2xSDX15 had an unfair advantage in the latest round of testing since it used two CE4000s. Since it's impractical to use two amps with every sub, at least knowing a single-amp sub's input distortion would help interpret the overall results. | ||||
