Gradient Evidence MK2 *new* - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Discuss Gradient Evidence MK2 *new* in the Manufactured Speakers and Subwoofers forum; Gradient Evidence MK2 *new* Manufacturer: Gradient Model: Evidence MK2 Provided by: Ilkka Manufacturer link: Gradient Price: 1990 EUR (pair) Manufacturer specs: • Radiation patterns: ...
Old 12-22-07, 02:38 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Model: Evidence MK2
Provided by: Ilkka
Manufacturer specs:
• Radiation patterns: bass: sphere; cardioid: midrange & treble
• Frequency response: 45-20000Hz +/-2dB, 29Hz -6dB
• Impedance: 4 ohm
• Sensitivity: 86dB/2.83V/1m
• Recommended amplifier: 50-250 W
• Drivers: 1×200 mm (8”) long throw woofer, 1×176 mm (6 1/2”) fiberglass midrange, 1 coaxial aluminum
• Crossover frequencies: 200 Hz and 2800 Hz
• Connections: Bi-wireable. Thick cable (up to 30mm2) or 4 mm banana plugs or forks
• Finish: Solid cherry or Maple or Black painted cherry, dark grey cloth
• Features: Bass level adjustment, 3 dB
• Dimensions (WHD): 21 × 100 × 30 cm
• Weight: 22 kg
Configuration as tested:
Crossover: No
Amplifier: Single channel from a Crown CE4000
Orientation: Coaxial driver facing the mic, woofer on the side
Only single speaker tested but results are showing the performance of a pair (+6 dB)
Old 12-22-07, 02:38 PM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Gradient Evidence MK2
+/- 3 dB points: 53.3 Hz - >200 Hz
Old 12-22-07, 02:39 PM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 12-22-07, 02:39 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 12-22-07, 02:39 PM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
reserved
Old 01-05-08, 04:16 AM   #6 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Gradient Evidence MK2 *new*
DS-21 wrote: View Post
That's great output for a single 8 per side! Looks like a great set of mains to hand off to a super-capable sub.
Yes, even though the frequency response and therefore extension is pretty strange/bad for a ~30 Hz tuned ported speaker, it gives many subwoofers a run for their money when it comes to clean mid bass output.
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
Velodyne SPL-1200 MK2 *new* Ilkka Subwoofer Tests 8 03-08-08 04:02 PM
Bk XLS200-DF MK2 Ilkka Subwoofer Tests 6 07-30-07 12:08 PM
HSU VTF-3 MK2 (maximum extension) Ilkka Subwoofer Tests 4 03-30-07 06:14 PM
HSU VTF-3 MK2 (maximum output) Ilkka Subwoofer Tests 3 07-17-06 02:23 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
