SVS PB12-NSD *new* - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
SVS PB12-NSD *new*
Discuss SVS PB12-NSD *new* in the Manufactured Speakers and Subwoofers forum; SVS PB12-NSD *new* Manufacturer: SV Sound Model: PB12-NSD Provided by: SV Sound Manufacturer link: SV Sound , L-Sound Price: 711 EUR, 599 USD ...
Old 12-22-07, 02:36 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
SVS PB12-NSD *new*
Model: PB12-NSD
Manufacturer link: SV Sound, L-Sound
Price: 711 EUR, 599 USD (+shipping)
Manufacturer specs:
• SVS designed/built long-throw 12" driver
• Full-featured 325 watt BASH digital amp
• Computer Assisted Design (CAD) enclosure
• Dual CNC'd internal braces
• Three color choices with removable grill
• Front-firing woofer/port for easy installs
• Built-in, flush-mount amp configuration
• Compliant floor mounts (six)
• Patented 4" high-flow flared porting (in and out).
• Extra heavy-duty removable 8 foot power cord
• "Seamless" cabinet design in three colors
• +/-3dB 18Hz-200hz anechoic extension
• Size: 18" wide x 21" high x 25" deep.
• Weight: 74 pounds
Configuration as tested:
Phase: 0 degrees
Crossover: Bypassed
Orientation: Woofer and port facing the mic
Old 12-22-07, 02:36 PM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Svs Pb12-nsd
+/- 3 dB points: 15.3 Hz - 62 Hz (crossover min)
+/- 3 dB points: 25 Hz - 146 Hz (crossover max)
Old 12-22-07, 02:36 PM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Svs Pb12-nsd
Old 12-22-07, 02:36 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Svs Pb12-nsd
Old 12-22-07, 02:37 PM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Svs Pb12-nsd
reserved
Old 12-22-07, 06:54 PM   #6 (Link)
Shack Podcaster
Alias: Marshall
Loc: Hudson Valley, NY 12569
eugovector's Avatar
User: #2411
Since: Sep 2006
eugovector is online now
Re: Svs PB12-NSD *new*
Pretty stunning what $600 can get you.
Old 12-23-07, 01:41 AM   #7 (Link)
Loc: Lower Alabama
Sonnie is offline
Really... 15Hz from a 12" sub at 600 bucks... ridiculous!
Sonnie
Old 12-23-07, 11:30 AM   #8 (Link)
Alias: Steve
SteveCallas's Avatar
User: #263
SteveCallas is offline
SVS has really stepped it up as of late.
Old 12-23-07, 03:51 PM   #9 (Link)
Shack Podcaster
Alias: Marshall
eugovector's Avatar
User: #2411
Since: Sep 2006
Yeah, I keep an "wishful thinking" list, and I've just updated it from a single SVS 20-39+ tube to 2 - PB12-NSD. Now all I need is someplace without shared walls and a little more floor space.
Old 12-23-07, 06:14 PM   #10 (Link)
Alias: Matt
Loc: Allentown, PA
User: #11567
Since: Sep 2007
E-A-G-L-E-S is offline
This is the same PB-12NSD that has been out for some time now replacing the ISD, correct? Or did I miss that they re-did the NSD?
Edit: Nevermind, I see it was just a new from factory nsd as opposed to a used one. Sorry.
Old 12-23-07, 08:34 PM   #11 (Link)
Silver Supporter
Alias: Geoff
Loc: Columbia, MO
User: #1654
Geoff Gunnell is offline
Ilkka has tested two versions recently, one had an 'improved' amp -- SVS has not commented on exactly what is shipping currently.
Old 01-04-08, 06:48 AM   #12 (Link)
SVSound
Alias: Ed
Loc: Upstate New York
User: #1779
Ed Mullen is offline
Geoff Gunnell wrote: View Post
The first PB12-NSD Ilkka tested was privately owned. When we saw the FR, we knew there was a problem with the amp. We contacted the customer through Ilkka and replaced that amp for the customer.
We discussed testing another PB12-NSD for his next shoot-out. Our Euro dealer L-Sound servicing Finland sent Ilkka a new production PB12-NSD from their inventory. It was not tested prior to being sent to Ilkka.
We did upgrade the amp in the PB12-NSD several months ago and the unit Ilkka tested has the newer amp. The new amp had been shipping for a few months and was in-stock with all dealers at the time Ikka tested the 2nd PB12-NSD.
Ed Mullen
SVS Customer Service
www.svsound.com
sales@svsound.com
techsupport@svsound.com
"What We Do In Life, Echoes In Eternity"
Old 02-11-08, 01:11 PM   #13 (Link)
New Member
Alias: Chris
Loc: Richmond, VA
User: #11379
Since: Sep 2007
Mr772 is offline
Ed Mullen wrote: View Post
Is it possible for you elaborate on the upgrade to the amp?
Old 02-11-08, 03:00 PM   #14 (Link)
SVSound
Alias: Ed
User: #1779
Mr772 wrote: View Post
We worked with Indigo and spec'd a few changes to improve response linearity, but we won't publicly discuss details beyond that. We make improvements/changes to all our amp platforms on a routine basis.
Ed Mullen
www.svsound.com
sales@svsound.com
Old 03-03-08, 11:14 PM   #15 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
Re: Svs Pb12-nsd
Ilkka wrote: View Post
is the number in red correct? or a typo?
Old 03-06-08, 07:01 PM   #16 (Link)
New Member
Alias: Brian
Loc: WV
User: #8813
Since: May 2007
BTT917 is offline
Re: Svs Pb12-nsd
mike c wrote: View Post
Yes, it's correct. Since it is being run with basically no crossover, there is output at higher frequencies than the first FR spec. Therefore, the -6dB point (from maximum output) occurs at a higher frequency.
In other words, when you look at the FR plot, the "crossover min" has a maximum output of ~90dB @ about 37Hz. With the "crossover max", the maximum output is greater than before at ~92dB, and occurs at ~73Hz. So to find the "+/- 3dB" range you have to find the frequency which is 6dB lower than maximum.
Old 03-06-08, 07:53 PM   #17 (Link)
Alias: mike
mike c's Avatar
User: #147
mike c is offline
Re: Svs Pb12-nsd
BTT917 wrote: View Post
thanks! now I understand
Old 03-15-08, 03:18 PM   #18 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
Re: SVS PB12-NSD *new*
Great Job SVS!!
Actual Tune seems about 20 Hz+. Did you measure itIlkka?
Yamaha RX-V2500, Wharfedale Diamond 9.6 Fronts, Wharfedale Diamond CM Center, Diamond DFS Surround and rear, Behringer FBQ 2496, Dual RL-P18s 625L LLTs, Dual TA-2400 Pro (2 * 2000 W Amp), Samsung HD870 DVD player, Carada BW 16:9 106" screen, Epson TW-2000, 60 Gb PS3
Important HT proverbs:
- "You can never have too much headroom" (talking about bass)
- "you can never have too big a screen" (talking about still pictures)
Projector selection basics
Epson TW 2000 review
Old 03-16-08, 08:59 AM   #19 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
blaser wrote: View Post
Great Job SVS!!
Actual tuning frequency is around 17 Hz.
Old 03-16-08, 02:25 PM   #20 (Link)
Pharaoh Moderator
Alias: Ahmed
Loc: Cairo-Egypt
Blaser's Avatar
User: #2269
Since: Aug 2006
Blaser is offline
So why are THD curves minimal at 20-21 Hz??
Old 03-16-08, 03:26 PM   #21 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
That's just how the Helmholz resonator works, and also because the port doesn't work optimally when the air speed rises (=port compression). The THD minimal isn't exactly at the tuning frequency but instead a few hertz above it. You can see the same phenomenon with pretty much every ported subwoofer I have tested.
Old 03-17-08, 10:05 AM   #22 (Link)
New Member
Alias: Sam
Loc: SC
User: #18234
Since: Mar 2008
Sam AV is offline
Ilkka,
What is your opinion of the PB12-NSD (new version) vs the HSU VTF-3.3.
Thanks.
Old 05-18-08, 11:45 AM   #23 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Sam AV wrote: View Post
Ilkka,
Thanks.
Sam,
Having measured both of them outdoors and also heard both in my own room, I'd say they are really close when it comes to pure performance or sound quality. Since the size and finish are pretty much identical, I'd get the one that I can get for less $.
Old 05-18-08, 12:14 PM   #24 (
