| Subwoofer Tests DIY TC Sounds LMS-5400 18" sealed 100L LT *new*Discuss DIY TC Sounds LMS-5400 18" sealed 100L LT *new* in the Manufactured Speakers and Subwoofers forum; DIY TC Sounds LMS-5400 18" sealed 100L LT *new* Manufacturer: DIY
Provided by: Ilkka
Manufacturer link: -
Price: -
Please contact if you would like to have the same ... |
| | #1 (Link) | |||
| DIY TC Sounds LMS-5400 18" sealed 100L LT *new* Manufacturer: DIY Provided by: Ilkka Manufacturer link: - Price: - Please contact if you would like to have the same kind of subwoofer (with better cabinet and numerous finish options) being built for you.Manufacturer specs: • Woofer: TC Sounds LMS-5400 18” (DVC 2x2 ohm) • Amplifier: Crown CE4000 (~3600 W @ 4 ohm bridged per amp) • Enclosure: 100 liters, 21mm baltic birch all around, 42mm front baffle, well braced, total weight with woofer around 60 kg / 132 lbs • Signal processing: Behringer DCX2496 Configuration as tested: Phase: 0 degrees Crossover: Bypassed EQ: Linkwitz Transform via DCX2496, ~13 dB DC gain Subsonic filter: No Orientation: Woofer facing the mic ![]() | |||
| Bookmarks |
| Thread Tools | |
Similar Threads | ||||
| DIY TC Sounds LMS-5400 18" + 2x18" PR 200L *new* | Ilkka | Subwoofer Tests | 53 | 05-31-08 12:25 AM |
| DIY TC Sounds LMS-5400 18" sealed 100L *new* | Ilkka | Subwoofer Tests | 7 | 01-22-08 03:52 PM |
| DIY CSS SDX15 sealed 100L *new* | Ilkka | Subwoofer Tests | 4 | 12-22-07 02:45 PM |
| FS: Rare TC Sounds 12 Inch LMS 5400 | photocrazy8 | Classifieds - Speakers and Subwoofers | 6 | 12-04-07 07:46 PM |
| DIY Adire Audio Tumult 15" MK1 sealed 100L | Ilkka | Subwoofer Tests | 6 | 07-30-07 12:11 PM |
