DIY CSS SDX15 sealed 100L *new* - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Discuss DIY CSS SDX15 sealed 100L *new* in the Manufactured Speakers and Subwoofers forum; DIY CSS SDX15 sealed 100L *new* Manufacturer: DIY Provided by: Goodguy Manufacturer link: Woofer bought from LumoAudio Price: - Please contact if you would like to ...
Old 12-22-07, 02:44 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Manufacturer: DIY
Price: -
Please contact if you would like to have the same kind of subwoofer (with better cabinet and numerous finish options) being built for you.
Manufacturer specs:
• Woofer: CSS SDX15 (DVC 2x2 ohm)
• Amplifier: Crown CE4000 (~3600 W @ 4 ohm bridged)
• Enclosure: 100 liters, horizontal sonotube
Configuration as tested:
Phase: 0 degrees
Crossover: No
EQ: No
Orientation: Woofer facing the mic (picture is showing wrong orientation)
Old 12-22-07, 02:44 PM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: DIY CSS SDX15 sealed 100L
+/- 3 dB points: 24.5 Hz - >200 Hz
Old 12-22-07, 02:45 PM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 12-22-07, 02:45 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 12-22-07, 02:45 PM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
reserved
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
DIY TC Sounds LMS-5400 18" sealed 100L LT *new* Ilkka Subwoofer Tests 5 08-03-08 11:11 AM
DIY TC Sounds LMS-5400 18" sealed 100L *new* Ilkka Subwoofer Tests 7 01-22-08 03:52 PM
DIY CSS 2xSDX15 sealed 140L *new* Ilkka Subwoofer Tests 4 12-22-07 02:46 PM
Plans for CSS SDX15 M4rk_23 DIY Subwoofers 7 12-11-07 08:54 PM
DIY Adire Audio Tumult 15" MK1 sealed 100L Ilkka Subwoofer Tests 6 07-30-07 12:11 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202
