Audio Pro Level 110 *new* - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Discuss Audio Pro Level 110 *new* in the Manufactured Speakers and Subwoofers forum; Audio Pro Level 110 *new* Manufacturer: Audio Pro Model: Level 110 Provided by: Mika P. Manufacturer link: Audio Pro Price: 399 EUR Manufacturer specs: • ...
Old 12-22-07, 02:48 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Model: Level 110
Price: 399 EUR
Manufacturer specs:
• Type: Powered subwoofer with built-in ace-bass® amplifier, bass reflex
• Amplifier: 400 W rms
• Woofer: 10” long-throw
• Frequency range: 23-100 Hz
• Lo-pass filter: 50-100 Hz, variable 24 dB/octave
• Hi-pass filter: 100 Hz, 6 dB/octave
• Dimensions (WxHxD): 350x410x390 mm
• Weight: 16,8 kg
• Connectors: Line and speaker level input, heavy duty binding post and RCA-input
• Adjustments: Auto standby, variable level adjustment, variable frequency adjustment between 50-100 Hz, variable phase adjustment 0-180 degrees
• Cabinet: MDF
• Finish: Vinyl foil
• Colors: Light cherry/champagne or walnut
Configuration as tested:
Phase: 0 degrees
Crossover: Max
Orientation: Standard down-firing orientation, port facing the mic
Old 12-22-07, 02:48 PM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Re: Audio Pro Level 110
+/- 3 dB points: 22.5 Hz - 55 Hz (crossover min)
+/- 3 dB points: 23.1 Hz - 108 Hz (crossover max)
Old 12-22-07, 02:48 PM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 12-22-07, 02:48 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 12-22-07, 02:49 PM   #5 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
reserved
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Similar Threads
Need help with my pro audio stuff dynamowhum System Setup and Connection 19 09-05-07 10:23 AM
Next Level Audio and Video Sonnie Forum Announcements | News 2 11-21-06 07:46 PM
Audio Pro Sub Focus Ilkka Subwoofer Tests 3 07-17-06 02:34 PM
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200
