Genelec 7073A - Home Theater Systems - Electronics and Forum - HomeTheaterShack
Go Back   Home Theater Systems - Electronics and Forum - HomeTheaterShack > Manufactured Speakers and Subwoofers > Subwoofer Tests
Subwoofer Tests
Genelec 7073A
Discuss Genelec 7073A in the Manufactured Speakers and Subwoofers forum; Genelec 7073A Manufacturer: Genelec Model: 7073A Provided by: Powerking Manufacturer link: Genelec 7073A Active Subwoofer Price: $8895 Manufacturer specs: • Short term ...
Old 07-16-06, 02:43 PM   #1 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Genelec 7073A
Model: 7073A
Price: $8895
Manufacturer specs:
• Short term RMS @ 1 m (halfspace) 124 dB SPL
• Input channels 6
• Sum out outputs 1
• Driver 4 x 12"
• Free field frequency response 19 - 85(120) Hz +/-3 dB
• Bass level +6 to -12 dB
• Bass roll-off 0 to -6 dB (2 dB/step) @ 20 Hz
• Phase adjustment 0 to 270° (90°/step) @85 Hz
• Amplifier power 1000 W
• Dimensions (H x W x D) 524 x 1440 x 558 mm, inches 20 5/8 x 56 11/16 x 22"
• Weight 120 kg (265 lb)
Configuration as tested:
Phase: 0 degrees
Bass roll-off: 0 dB
Orientation: Woofers facing the mic, 4 m distance to mic (all results compensated to 2 m distance)
Old 07-17-06, 10:12 AM   #2 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
+/- 3 dB points: 17.5 Hz - 110 Hz
Old 07-17-06, 10:13 AM   #3 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
Old 07-17-06, 02:24 PM   #4 (Link)
Shack Moderator
Alias: Ilkka
Loc: Finland
Ilkka's Avatar
User: #991
Since: Jun 2006
Ilkka is offline
The mother of all Genelec’s. It’s basically four 7070A’s strapped together, but it costs less than three of them. Weighing a whopping 120 kgs, it’s clearly the largest sub I’ve ever measured, and probably ever will. The shape of the frequency response is pretty much identical with its smaller brothers, flat being the key word. This suits better for rooms not having much deep bass room gain. The low pass filter slope is very steep, but the lowest setting is only around 80 Hz, meaning a proper 2-channel use requires an external filter. The maximum output capability is extremely good in mid and upper bass range, very good in deep bass range. THD stays really low throughout the whole operating range up to 105 dB output level. The deep bass distortion climbs up pretty quickly above this. 3rd harmonic is the dominant one, which is typical for every Genelec subwoofer. Group delay grows pretty large below 30 Hz, but doesn’t go above the 1 cycle value. The steep high pass slope shows some excessive ringing. The spectral contamination test shows much higher than average maximum output capability with much lower than average overall distortion. The build quality is similar to other Genelec’s, meaning extremely good. This is a monster subwoofer, make sure you have a proper space for it.
+ Very good extension
+ Flat frequency response
+ Extremely low overall distortion up to very high output levels
+ Steep crossover
+ Build quality and sturdy enclosure
- High deep bass distortion at high output levels
- Some ringing around the tuning frequency
- Very large enclosure
« Home Theater Shack > Manufactured Speakers and Subwoofers > Subwoofer Tests »
Mach 5 Audio
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191
